Tyre Pressures
2 minutes ago, KenONeill said:
Er, 3 of us have independently calculated that the process as described doesn't go past 95% by volume. Since O2 is denser, I'd expect the percentage of N2 to be lower than than the volume.
Your calculations assume the tyre contains regular air at the outset. I am saying it already has a high nitrogen content having been filled with nitrogen prior to the demo.
  • Replies 112
  • Views 30k
  • I love the whole video TBH. Unfortunately, there are plenty of people in this world who (and I quote verbatim one that I once met ) "don't believe in science". They will always be the victims of
  • OK, I'll bite. How does filling a tyre with 100% Nitrogen rather than the more usual 80% exempt it from Gay-Lussac's law (also sometimes known as the pressure-temperature law).
  • 1 atmosphere of air pressure will be in the tyre before the nitrogen is inserted. The tyre will thus be inflated with a mixture of pure dry nitrogen and air. Unless there is a clever method of air rem
His process works for a 98% N2 fill, in principle; it's just that it doesn't work out with his stated method and pressures. OK?
Yes, I agree. I was quoting 98%, as that was the value shown on the nitrogen meter in the video.
What a bore this topic has become 😔
  • Sponsor
:D So don't read it...
I have found this topic quite stimulating, and would guess that many members who have actually taken part in the discussion would feel the same. It has gone a long way from where it started out, and I have learned how the TPMS works and a bit about nitrogen. We have had a bit of disagreement, which I hope we have now resolved, and a bit of humour.
Likewise; I was remembering stuff I'd not used since uni, and that's since the 1980s.
So my question is does the Octavia have a true TPMS tyre sensor set-up or is it just down to the ABS sensor picking up variances?
The Octavia that can just show a TPMS warning, even which tyre has as basic as it comes, ABS sensor / system showing.
A car, any car or vehicle that can show The Pressure in tyres, temp etc has a different system.
Just to close off the Nitrogen debacle
1. Rightly or wrongly, dry gases are seen as more stable for tyres inflation
2. Costco sell my prefered brand/size of tyres cheapest
3. Costco ONLY Nitrogen fill their tyres.
Conclusion, my placebo has been massaged
When I commit to a high speed corner I don't wonder whether my tyres will do the job, I Fn KNOW they will, as proved by my continual fight with my Crew Protection opening the windows & pretensioning the seatbelts & I still haven't been in a bloody ditch yet.
Wherever or not it actually works, I have been given confidence in the tyres & car's capabilities.
@Biggriff sorry for the thread Jack but, no the O3 has no separate sensor it's all done by variances in ABS sensor readings.
On 20/08/2019 at 13:52, Roottootemoot said:
“Nitrogen retailers - arseholes” :laugh:
Love that 🤣
On 17/08/2019 at 16:20, Gerrycan said:
A quick google search says pressure variance is 0.19psi per degree Centigrade so very nearly 2psi per 10 degrees C.
I forgot to account for absolute versus relative pressures. I worked from 10 °C is about a 3% change in temperature, which will give a 3% change in pressure, which based on 32 psi relative pressure (WRONG!) would give a change of about 1 psi. Using absolute pressure instead gives about 1.5 psi per 10 °C, starting from 32 psi. Starting from 40 psi gives your 0.19 psi per °C. (32 psi chosen as having been mentioned previously in the thread.)
The only time I've had a TPMS warning was when there was a screw in the tyre, although the tyre had not gone down.
