new tyres on front, rears only 6mm, ok?
17 hours ago, silver1011 said:
Far from it, my observation is that you enjoy quoting a lot of my posts and disagreeing with most of my advice being offered to others.
That's because your 'advice' is nonsense.
Driving around with a puncture repair to the tyre sidewall for 1500 miles is absolutely fine. Um, okaaaay …
Tyres with only 1.6mm grip left are safer than tyres with 3mm grip left. Um, okaaay …
Everything Michelin's marketing team say is true. Um, okaaay …
  • Replies 58
  • Views 17.5k
  • The legal limit in the UK is 1.6mm, most brand new tyres are 8mm, including the 1.6mm.   At 3mm there is still plenty of life left in them.   Take the fronts down to the wear bars,
  • To say the least this is not ok and illegal in most countries, if a puncture is out of area for an umbrella plug the tire is to be changed. And using an emergency plug too far out on the side is insan
All your post does is prove you're tuned into your view and no one else's. A blinkered view.
At least I'm supporting my advice with personal experience and quotes from industry experts. Where's yours?
It was 15,000 miles, not 1,500 miles.
Can a tyre with 1.6mm can offer more grip in certain conditions than a tyre with 3mm, yes, it can.
I didn't claim everything Michelin marketing team say is true.
I'll leave the strange cat memes to you, Odd.
I've have a quick look at the numbers regarding water handling of various depth tread.
Based on an original depth of 8mm:
1.6mm would have 53% the water shedding capacity of a tyre with 3mm depth.
6.4mm would have 80% the water shedding capacity of a tyre with 8mm depth.
1.6mm would have 20% the water shedding capacity of a tyre with 8mm depth.
This is based purely on the water capacity of a tyres main grooves and doesn't take into account the much reduced depths of smaller sipes.
I think its clear that a tyre with 1.6mm remaining has much reduced capability for UK use.  It's not a good idea to base your tyre usage on stats that are from dry tyre testing, when in December in the UK, whether they are from a well regarded manufacturer or not.
  • 4 weeks later...
I usually change my tyres when the cord starts showing
This isn’t your everyday normal stupid, this is advanced stupid.
Haha was a joke, i change at 1.6mm not before.
i will add though at around 3mm the effectiveness of the tyre in wet conditions is reduced and more likely to aquaplane as you cannot disperse water to the same extent.
i drive in the knowledge of this and i know from under 3mm i have to go slower through standing water.
Edited by BigJase88
Edited by silver1011
No I got the joke, but the gentleman didn’t use a smiley so I thought I would be «funny» as well. Wink wink.
SWMBO also drives our car and I couldn't rely on her to drive more carefully (recently she's started driving like she thinks she's an F1 driver, I actually hope she gets a speeding ticket as she needs to learn but won't listen to me) with less than 3mm tread depth so I always change at 3mm.
Edited by PetrolDave
