Amundsen MIB2 Firmware Update
Hello @pab567,
thanks a lot for the work and knowledge you share with all of us here.
Can you please help me with the update for the unit attached in the image.
Thanks a lot in advance.
P.S. I know navigation is also out of date, I'm currently downloading update.
  • Replies 4.6k
  • Views 838.9k
On 28/11/2021 at 09:37, DrNickAsch said:
new issue: I have done a small error, now my head unit sees the SD-card, it says: software update, but when I try to perform the update, I can't select the SD
any clues?
Emergency update...
On 28/11/2021 at 13:54, jozko76 said:
Ahojte,
chcel by som urobiť update na Skoda Superb 3 s infotainment Amundsen na Grid menu ako na foto.
pab567 vieš mi prosím ťa s tým pomôcť?
This requires unit to be hacked so I cannot help you 😞
All check your PMs.
Hello @pab567,
can you please send me link for latest firmware for my S3 Amundsen 5Q0035864B / H30 - I am on version 0359 now.
Thanks a lot.
PM
20211203_084501.thumb.jpg.3dc93af67d77862491fd8ba5c900029c.jpg20211202_091344.thumb.jpg.2204d5fca562f8d461b9167c89f8353c.jpg20211203_084506.thumb.jpg.cef973f9a75513e829efb02063ec7345.jpg
Hello Pab567 could you help me with this please ??
Many Thanks.
On 29/11/2021 at 22:37, pab567 said:
Emergency update...
OK, thanks for the info, now just to know how to start this. Can't find a link on how to start this emergency update
You must have the unit open and connected to PC via UART
ok thanks, not for me, this kind of procedure. So I'll be looking out for another solution
Hi i'm looking to update my firmware from 0241 to 0253 can anyone help?
Model number?
I should be able to have it repaired but you must deliver it to me to Poland.
1 hour ago, pab567 said:
Model number?
PM
Hi any update in my one please
Also I have some problems in my Skoda octavia mk3 2016 need some help
Trouble codes:
        P256400 - Turbocharger Boost Control Position Sensor Circuit            Low
I change turbo actuator but still same fault code coming.
Any ideas please
Hi, it would be great if you can send me the update file my system. Also, a small query, its an L&K model in India. Will the update file keep the localisation setting or will there be a change to Euro localisation. Just checking up I can update without an issues or changes.
Hello, I have a MIB STD2 PQ NAV (x3xx) that is stuck at the logo. Is it possible to reinstall the firmware? (Like, just download the firmware to a SD card or USB and install it)
Trouble codes:
Any ideas please
You might want to take this problem to the main part of the MK3 Octavia Forum.  This thread is for firmware updates to Amunsden MIB units.
One of two things has gone wrong here.  The MIB system is now in emergency boot-mode.  You have either tried to patch the system with SOP2.x or SOP4.x firmware.  Version x4xx firmware won't work on x3xx systems - or you have corrupt files on your SD Card or you have extracted them incorrectly.
Just make sure you have the correct SOP3.x firmware for your system (0363 is your latest), then copy that software onto a freshly formatted SD Card, then restart the MIB unit.  You will also need to remove any other SD card in the system other than your update SD card.  You also need to make sure that you haven't copied the files using a MAC - as this leaves files on the SD Card that stops the upgrade from working properly.  Use Windows or Linux for this operation.
20 minutes ago, varaderoguy said:
0363 is your latest
Thanks for the reply, I haven't tried to update it (I don't have the files, all the info I provided from my radio was from the stickers on it) so it may be just bad luck. Then I'd like to ask, is there any preferred site to download this update (or could someone send me a link?)
Thanks in advance,
Max
Hi, I would really appreciate - if at all possible - the updated firmware for my unit! Info is below:
Thanks in advance :)
You need to speak with @pab567 who will hopefully be able to assist.
No update available for your unit.
