Amundsen MIB2 Firmware Update
Firmware has nothing to do with the navigation system's map data.
  • Replies 4.7k
  • Views 921.6k
Cairus, thanks for the reply.
As far as I am aware there is nothing wrong with the map data - the issue seems to be that there is some sort of incompatibility between the more recent map data and my Amundsen unit.
With old versions of the map data the unit will display all of the map data - however the road layouts and speed limits are not up to date.
With more recent versions of the map data loaded, the sat nav works fine, and displays everything except small village names - cities, towns and even street names are all there - but no villages.
As a check, I have loaded the same map file into a friends Golf and the village names are displayed, so it must be something with my Amundsen unit.
Any ideas anyone?????????????
GPS Antenne OK?
Everything other than the village names works OK.
Using the same map data on the same Skoda SD card shows the villages on a similar unit in a friends Golf but not in my Octavia.
On that basis there must be a difference between the two Amundsen units, and the firmware might be the difference?
I don't think the firmware on my unit has ever been updated, so I think it is worth trying an update from version P0241T to P0253T.
Can anyone help me in obtaining the files for the update?
No image preview
3.4 GB file on MEGA
No warrenty
Thanks - what is the key?
Normaly No Key..
https://mega.nz/file/A3kVnRrb#5USQHMiRRmq3dhy1cjEvacw4y6GoXxRMGnsVhhOIhAw
Thanks - the update installed OK but did not solve the problem - still no villages.
What is the very latest firmware - I understand 0253 was the last 'official' update.
I say it is Not the Solution
Hi everyone hoping to get some help with my mib unit I am having issues connecting to android auto
On
MST2_EU_SK_ZR_P0245T
5Q0035874A
I have tried everything I'm aware of so far and now I'm thinking it's got to be a software/firmware issue.
I've tried several different OEM cables and 5 different phones (iPhones and Android) I have replaced the usb port with " 5Q0 035 726 E " aswell as a new HSD cable from the head unit in the glovebox to the back of the USB I have also tried 3 different byte 19 codes and checked that android auto and is enabled in 5F module the usb has been set to "full" but after all of that I still cannot get any to be recognised it seems like the usb just isn't sending data I haven't had the car very long maby a month but I have yet to get smartlink to work Bluetooth seems ok however it does drop out from time to time and is around 15/20 seconds delayed I would really like to get Android auto working as I do a lot of motorway miles and I like being able to easily change music to podcasts ect.. if anyone can help or possibly point me in some other direction I would massively appreciate it 🙏
Hi
I have the apparently common 00:00 glitch on the head unit of my Amundsen 2 head unit. I believe I need to upgrade its firmware to 255T, and that you can help with this? I'd be very grateful! Thank you in advance.
6 hours ago, PhilipS1958 said:
Hi
What is this 00:00 glitch?
The digital time clock on my infotainment system is stuck at 00:00 midnight, except for a brief switch to 06:28 every half minute or so. It's not uncommon, and other streams here (and Google searches elsewhere) have indicated that's it's fixable via a firmware upgrade, either through a specialist or a main dealer (both very expensive routes), or DIY via a patch that can be sourced from here.
Whoever can help, I'd be very grateful!
I have the Patch
The actual problem lies with the instrument cluster; there is a programming error in its EEPROM. Updating the 5F unit—the radio—was a customer-friendly workaround, but it does the job.
Is there a new firmware availabl for the skoda kodiaq?
Device Part number:  565035864
Hardware: H41
Software: 0480
Thanks Andreas
No, FW0480 is final by Skoda
Hello! I have a 2019 Škoda Karoq with the radio shown in the attached photo. Is there any new software available for it, and if so, where can I download it? Thank you!
Hi
I download from MIB Vault the 3.3gb file MST2_EU_SK_ZR_P0369T. However this variant is for Amundsen (Navigation). I have the Bolero (Non-Navigation).
Has anyone got a link for the Bolero update?
Cheers
Dale
Recently Browsing 1
