Amundsen MIB2 Firmware Update
On 25/09/2026 at 10:57, Albos said:
Thank you for answer. I'm afraid someone more experienced than me should do this. )
I can do it for you, as I can see you are from Czech Republic and I am in Poland so shipping costs will not kill it...
@CrazyWolf @Rocketeer125 check your PMs for MST2_EU_SK_ZR_P0480T download link
  • Replies 4.7k
  • Views 924.4k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
@mpg_cloud @Cairus If you need to update to version 0480 and activate CarPlay, send me a message.
I have the Solution and dont need help
I have a 2018 skoda octavia and Wondering if there is any update for my unit? @pab567
I have a problem where smartphone disconnect frequently from car play or android auto. Might just be a problem with usb port. Anyone have a doc or video on how to check for loose connection or replace the USB unit?
I replaced the original battery less than 2 years ago and the latest one is not dead. I checked for parasitic draw but not found any. Wondering if mib intermittently causes the problem.
Red
Download link for MST2_EU_SK_ZR_P0480T sent in PM
@red-ireland regarding your problem which phone do you have and are you using original cable for connecting to android auto/carplay?
iPhone 12, pixel 8a, oppo find x9 ultra. All of these phones came with USBC and the car is usba so not able to use original cable but most of my other cables are ugreen.
@red-ireland friend of mine had similar problem. Then he tried with higher quality cable and there was no more issues.
Did you try using any carplay bluetooth adapter ?
CarPlay requires a high-quality cable that supports both power and data transfer (at least USB 2.0 speeds of 480 Mbps). "Charge-only" cables will not work.
Thanks @pab567 for such a quick response. Have a few follow up questions on procedure via pm thanks again.
I had read that they were problematic but considering I'm only looking for android auto have gone for the latest Motorola one from Amazon. I like that it has a physical power button and fast switching between phones.
Good suggestion.
Carlinkit's adapters are very good. I am using it (mini ultra 3). It is almost as good as using it with cable. Most importanlty no delay while listening songs. Sometimes while playing songs it can glitch for 1 milisecond and after that it continues normally. Glitch happends rarely.
If I was in your shoes I would first try with some better cable, like Samsung's original, if that doesn't help then I would continue with other methods. Good luck.
I've just bought a 2019 Octavia and only complaint I have is the infotainment system I'd love to replace it with a proper head unit but VAG have scuppered that plan and then to discover that it'll randomly crash and reset whilst using CarPlay just tops it off. I'm wanting to uplift my firmware but just need a reliable link to the software attached
I've tried multiple cables of various brands and price brackets without success.
No warrenty
https://mega.nz/file/lrc1BaCD#nq_LSllnN-vDCL_fK6YVGXCMPosigM-ZrRJ0RBJsNqA
Managed to uplift to latest but still getting crashes despite testing multiple USB cables and resetting CarPlay on my iPhone 16 pro max which is on latest iOS. Where to go from here?
OEM iPhone cable?
On 07/11/2025 at 14:16, pab567 said:
Sent in PM
Hi Pab567, Google has brought me here to you. Are you able to help me getting the software upgrade MST2_EU_SK_PQ_P0369T for my 2017 Yeti radio please?
Unfortunately I don't have it, 0359 is the most current firmware I have
OK, no worries. Thanks for responding 👍
Hi all,
I'd like to update my Karoq's MIB2 High to the final SKG13 release. Could anyone who has copy of MHI2_ER_SKG13_P4526 (MU 1440) share it, or confirm it's the right target for my unit?
Car: Skoda Karoq 2018, UK
System info:
- SW train version: MHI2_ER_SKG13_P4514_1 (1163)
- SW MU version: 1163
- Part number: 565035021B
- Hardware: H54
Unit is unmodified (no GEM, no toolbox, no patches).
Main reason: improving SmartLink/CarPlay stability with an iPhone 18 Pro.
If anyone can share a link via PM, that would be much appreciated. Happy to report back once done.
Thanks in advance!
Hi, I'm trying to update, but I can't find the link to do so. I tried Mibsolutions, but it seems to be having problems
could someone please send me the download link for MST2_EU_SK_ZR_P0369T?
My current version is MST2_EU_SK_ZR_P0359T
Thanks.
Hello, I'm on MST2_EU_SK_ZR_P0245T with GEM3.5 and want to activate carplay via toolbox, but i can't figure out, if i need to/should upgrade the firmware first. If that is the case, i would like the 480 version.
Hello
I am having problems with my Sat Nav not displaying village names, an issue I have been trying to solve since 2024. It's a very puzzling issue as the same map file loaded on my friend's Golf displays the village names!
My Octavia Scout still has what I suspect is the original firmware:
MST2_EU_SK_ZR_P0241T
I don't know if there is some incompatibility between the old firmware and the newer map files (if I install an older version of maps the names are displayed), it might be worth trying an update to:
MST2_EU_SK_ZR_P0253T
I don't need any fancy connectivity upgrades, just trying to fix the maps.
I cannot seem to find anywhere to find the file - can anyone help?
