Amundsen MIB2 Firmware Update
Hi everyone,
does anyone have MST2_EU_SK_ZR_P0369T?
Thanks in advance!
  • Replies 4.7k
  • Views 913.8k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
Hi @pab567
I have a Skoda Fabia III from 2016 which I plan on updating the firmware.
All my Radiologos disappeared recently for no reason an I hope they will come back with an Update
SW Train Version: MST2_EU_SK_ZR_P0245T
Part Number: 5Q0035874A
Software Version: H25.14.78_STD2Nav_EU
On mib-helper.com it shows:
Latest official firmware update: MST2_EU_SK_ZR_P0253T (MU: 0253, details).
Latest possible firmware update: MST2_EU_SK_ZR_P0480T (MU: 0480, details).
mibsolution.one is still down. Do you have a solution for me?
In addition, do you know a way to check, if my car is Smart Link ready?
Best regards
Hi, I have Skoda Superb 2018 Amundsen 5Q005864C HW H41 with boot loop (reboots after ~20s). Looking for MST2_EU_SK_ZR_P0478T (preferred) or P0480T. mibsolution is down. Can someone send me a safe download link via PM? Thanks!
@Strudl I sent you download link for MST2_EU_SK_ZR_P0253T in PM. Yes, your unit supports SmartLink.
@Adrian0li I sent you download link for MST2_EU_SK_ZR_P0480T in PM, however this is probably HW, not SW issue.
pab567 You're right, I tried it but it didn't work. Thank you so much!
Need MST2_EU_SK_ZR_P0369T or P0472T.
Current version: MST2_EU_SK_ZR_P0361T
Part number: 5Q0035840B
On 15/11/2022 at 12:54, Pipe84 said:
Hello.
I have a 2020 Octavia III 1.5 TSI.
This is the information that appears on my Amundsen (I don't know which Amundsen version I have honestly) , I don't know if there is any update.
In case there is a new version, I have several doubts:
- What improvements does the new version have?
- What steps should I follow to update.
- Is it possible to make a backup in case the update fails.
- What risks could there be.
Thanks.
Regards
Hello again, community.
I upgraded to version 480 years ago, and I wanted to know if there’s a newer version available to upgrade to. I think there’s a version 490, but I’m not sure, and I don’t know where to find it.
Thanks for your help.
Best regards
No newer Version
Edited by Cairus
Hi, I ve the firmware to update my MIB2 system (plus the usb port is suitable) to Smartlink working but what is the failure rate of doing this?
if the system did brick, can it be rolled back to previous f/w.....
Hi @pab567
I have a Skoda Fabia III from 2015 which I plan on updating the firmware.
I have an Issue with android auto connection, communication problem 8.
Part Number: 5Q0035840A
Software Version: H25.14.78_STD2Plus_EU
Best regards
Failure rate in MIB2 units, from my experience, is extremely low.
No rollback neededif update goes OK, if fails then emergency recovery only.
@allmacht I sent you download link for MST2_EU_SK_ZR_P0253T in PM
what is involved in an emergency recovery? thankyou.
full reflash of all the modules
Hello, my clock on head unit is not working. Trying to follow youtube to update the firmware but the MIB website is working.
Can you help with the latest firmware please. My current firmware below:
Installed SW train version:
MST2_EU_SK_PQ_PO359T
Installed SW MU version:
0359
Part number:
5L0035200D
Software version:
H28.28.133_STD2PlusPQ_EU
Thanks!
Hello guys. I want to update my 2016 Octavia. I have MST2_EU_SK_ZR_P0480T downloaded but seems that unit needs to be upgraded to MST2_EU_SK_ZR_P0253T first. Does anyone have MST2_EU_SK_ZR_P0253T to share?
Thanks in advance.
Jaak
Hello,
I have a Kodiaq 2021 with software version 0270, I would like to update to MOI3_EU_SKMQB_P30800P, unfortunately mibsolution is down. Does anyone have a link to it ?
Regards,
R
Edited by radizer
https://mib.plain.gg/files
Thank you. Will try.
Br,
Jaak
Thank you, it worked!
Hi mate can you send me this version of mib - MST2_EU_VW_ZR_P0480T for my passat b8?
You can Not Update direct To 0480…
Cairus - first of all, thanks for a link. Success to update from MST2_EU_SK_ZR_P0245T to MST2_EU_SK_ZR_P0253T. But next step should be MST2_EU_SK_ZR_P0366T? And if I try MST2_EU_SK_ZR_P0366T or MST2_EU_SK_ZR_P0367T I will again error that "Unable to read meta-information. Cant use update container...and so on. So...what would be solution here now? Didn't find any "middle version" from Ur link.
Br
Jaak
Hi @Cairus mate can you send me a link for this version of mib2 too?
- MST2_EU_VW_ZR_P0254T
and MST2_EU_VW_ZR_P0480T
Edited by Ceci_Spasov
I can do a software conversation for you. Write to me.
