MK1 Skoda Octavia VRS - Dead Locked Doors - How To Gain Access From Inside (Full Guide)
12 minutes ago, DeanVRS20VT said:
If this was helpful and you would like part two of the guide which includes, handle and door lock removal then hit the like button. I'll put the effort in and complete part two and get it posted. If this was helpful, again hit the like button as I can always make more guides on the MK1 platform.
An excellent write-up! Thanks!
Oh, and more please :)
Thanks for that informative post.
I've moved it to the Guides section and pinned it too.
nice write up, 3 things from experience doing it -
1- there are 2 torx screws are the bottom of the door card which can be removed before yanking the door card off.  takes some of the strain off it, also grabbing the door pocket gives a nice firm grip point along that bottom loosened end.
2 - a Stanley knife blade will cut open the casing of the oem  lock mech, reduces damage risk.
3 - a tip - I used 2 small size Allen keys for turning the cog. 1 to turn the cog and one to hold it in place - its sprung, so if you let go before its fully wound back it will reset.
bonus...
4 - when removing the cable to the outer grab handle count how threads are exposed and put the cable back in the same spot otherwise you'll find out when all is ressambled that the tension is wrong on the mechanism and it wont open again..
bonus bonus
5 - test the new mechanism with a screwdriver acting to close the latch a few times before you close the door.. lot easier snag your handiwork with the door open..
You can with patience and a pair of needle nosed pliers remove all the door card screws, or at least you could on my model.
Or at least I think that I did most of them at least, my memory is a depreciating asset.
Edited by J.R.
Edited by Dean
  • 4 months later...
Happened to me: Driver side rear door motor intermittent since early summer. I should have removed the lock then and converted it into manual use (not hard when it's on the table).
As a lazy guy I didn't and it gave up finally in late July. I had done some preparation, i.e. removal of screws from door panel, so removing it while door was closed, wasn't too hard.
But getting the door open took hammer, chisel, big pliers, side cutters, lot of curse words and 2 hours, eventually removing all the plastic parts on top of the metal parts. Got it open, removed the lock and noticed that I cant use it as manual lock as one of the pieces actually pressing the latch release got lost somewhere while hammering. Ouch. So no other options than buy a new lock
Fortunately those aren't expensive.
I did at some early point see that gear (step 12) but I managed to turn it from end to other and and no change; Still deadlocked so  I used brute force. It works in this case.
Edited by Kharon
Not even that: The motor itself *is not broken*. Also it's a quality product made by Mabuchi Motors so if you have this problem, it's most probably isn't the motor itself, but contact strips to the motor. 2p fault, buy a new lock.
Unfortunately I had to break whole lock to get door open, but it would have been totally fixable while it was intermittent. Saving a price of a new lock. Blah.
80e from FLAPs, cheapest ones from the net about 30 euros + freight + a week or so. Parts store got it for next day, can't complain too much. Metzger Autoteile says the box.
Edited by Kharon
price added
  • 1 year later...
Brilliant job by the OP, Dean: thank you!
Both the rear doors on my daughter's Mk I Octy were deadlocked shut. The method shown in pictures worked like a dream.
A few points I would make:
(1) Definitely get hold of the trim removal tools first, but don't be frightened to use a screwdriver when necessary.
(2) Make a colour printout of the instructions - the pictures will be much easier to see and understand.
(3) Wind the window all the way down before disconnecting the switch.
(4) No need for a dremel or similar to expose the cog: we drilled a few holes in the plastic casing and chopped a window into it with a small pair of offset wire cutters.
(5) Having done one door, the other one was very easy, because we knew exactly what to look for.
(6) We found that the door card clips popped apart (they are in two parts) with minimal damage, but when replacing the card, fit both parts of each clip to the door, then fasten the card in place with the Torx screws.
  • Administrators
Excellent! I'm so glad that you managed to fix it.
i used a stanley knife to cut through the plastic.. thats how soft it is, dont even need a drill :D
  • 1 year later...
Thanks for this how-to. it works for the back doors too as I tested today. I havent got so far as un deadlocking it, but I have visual pointers on problems in the door, rather than hunches, so I can now work towards fixing them!
Cheers!
  • 4 weeks later...
This s great, gong well so far.
I am at step 12.  WHich direction do I need to eurn the toothed wheel please?
Also, how far does it need to be turned?
eventually the lock poped open, so  I disconnected the wiring to the lock and now it is in "manual" mode.  Electric windows still work.
