Looking for a replacement mechatronic unit 6 speed vrs tsi
Been having a lot of problems with my dsg just had a new selector fork fitted and it now needs a mechatronic unit or repair but thinking a refurbished unit would be better does anyone know the best place to get one I love the car but I'm getting fed up now just want it fixed
Is your car not going anywhere at the moment????????
Might be worth mentioning your engine code......
It still drives but flashing prnds and no gear some times the engine code is ea888 I've not took it in anywhere yet
I guess finding a local garage you can trust is best option. Along with Google searching.
Hopefully someone may be able to help you more once they read your post.
Good luck with it.
Can be repaired cheaply from what I have come across over the years. Well known outfits repairing them. Google is your friend.
Who did you use to fix the selector fork?  Do you have faith in them?  If that was damaged it was probably the obvious place to start. Do they do mechatronic work or know who does.  Recommendations always helpful which is why you're on here but presumably they're also in your local area and they've made a repair already.
