Water leak front passanger door
Recommended Posts
Hello,
I got a problem regarding front passanger side doors on my Skoda Superb 3U4 2006 1.9.  after rain water leaks into cabin filling this under door well and slipping up into cabin. Perhaps someone got this problem and could advise ? I'm sure its not polen filter and I cleaned drain hole under battery.. Driver side is always fine and no water gathers after rain only this passanger side leaks.. 😞 Many thanks !IMG_20200526_114340.thumb.jpg.62de80e13c3d9dbaee83d2750029faf8.jpg
Link to comment
Share on other sites
Here is a clip showing the leak....
https://www.youtube.com/watch?v=nWpGwvUHJPQ
You need to take off the interior door card and then degrease and seal around the silver metal door regulator panel.  Use a decent quality sealant of your choice.  Exterior silicone will do.
Removing door card....https://www.youtube.com/watch?v=nGOqaoAdbsc
and
and
and  this
https://www.youtube.com/watch?v=B3bIi5MoA1E, but you only need the first part of the video!
Edited by Tdi1.9
  • Thanks 1
Link to comment
These cars all leak read this thread completely too and fix it correctly, pollen filter housing seal, door regulator panel, hood release cable grommet, sunroof drains etc etc
Link to comment
and
and
and  this
well its funny I'm no car guy so removed panel that was not hard and was thinking okay so need to add silicone between this panel and metal part did it and just after it dingd to me that u meant the two metal sheets that have seal in between.. (smart) so removed plastic panal again and also seald that. now just waiting for rainy day to see if it worked :D thanks for this tip :D
Link to comment
  • 4 weeks later...
I have same problem, I've done pollen filter and it was fine for a few weeks as no rain. It now ****ing in water again from somewhere. It hasn't got a sunroof so I can only think it's the door. It's only passenger side also which made me think it was still the pollen filter. When sealing the door do you remove the metal plate cover or just seal around it?
Link to comment
Sealing around will work, taking off the metal panel is more time/work, if you seal around the edge you can always remove it later if the window regulator or door locks fail both of which are common faults that require the metal panel to be removed.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
