Skoda Karoq Ambient Lights
Hi guys did this to my 2020 Karoq with the latest generation of the VCDS cable. First screen shot initial 2nd completed coding with 30 colours..... any one else attempted this...
Hello there
It is not the Amundsen navigation right?
no this just allows you change colours on radio and virtual cockpit
No. I mean your navigation system, your little computer. ;)
  • 3 months later...
Awesome, I miss my ambient lighting
  • 3 years later...
It's very beautiful
What's the steps on vcds to do it
Pls
Can you please share it with the coding?
thanks !
For those who think that the ambient light intensity is not good enough, you can modify the intesity value using vcds.
The default value is 37% but you can increase it up to 100%. You can still modify the intensity from your multimedia system.
In the attached image, the door panel has the ambient light set to 99% and the dashboard, is stock at 37%( I am talking of the values from vcds, from the multimedia system, they are both set to 100%).
You can do this from 09 control module, using 31347 security access code and go to adaptation.
There, you will need to modify the value for 4 channels, one for every zone: ENG128535, ENG128536,ENG128537, ENG128538.
Best of luck! 🥂
  • 5 months later...
Best of luck! 🥂
Man i've been looking for this information absolutely everywhere! Can you confirm what address affects what sets of lights, roughly? There's 5 strips (well, technically 6) but 4 addresses in there
Hi there,
They are divided in 4 zones, one for each door, one for the light above the glove box and one for the area from the steering wheel(2 + 1 +1). I don't know exactly what goes where in term of chanel but you easly find out by modifying one o them and see the result. Also, you cand set it to 127 which is the hight possible value but the dimming from the multimedia system won't work anymore and the lights will stay lit to 100%. Hope this helps.
  • 3 months later...
Helo, can you help me sir, when i go into VCDS and into -09 central electronics. - 10 - adaptation is greyed out, i entered the security access code: 31347
Best of luck! 🥂
In VCDS and into -09 central electronics. - 10 - adaptation is greyed out, i entered the security access code: 31347
Honza179, you need to make sure that your tester(vcds) is installed correctly and that it supports cars after 2016
How do i do that sir?
Question for those who have standard ambient lights (it doesn't matter if 10 or 30 variations): do Your footwells change the color too? In my car, which has ambient light standard (it's a 1.5 Style, equivalent to a SEL), according to the infotainemnt screen footwells change color BUT in reality they keep on staying white!
Instead, if anybody replaced with those RGB, can please tell me the part numbers and if I need other parts?
Mine are white and I can only change the intensity of them.
The reason that you see them colored on your MIB is due to a faulty coding. To make sure that your footwell lights are RGB, check the wires that plug into them. If you have 3 wires, then the lights are RGB, otherwise(2 wires) they are monochrome.
Further infos can be found here https://www.drive2.ru/l/591707406241650380/
As far as I can see, in the linked post there's everything I need to make them work/replace
Edited by Benja77
Recently Browsing 1
