Adding a wireless charger
We can retrofit the factory wireless charger for you 🙂
  • Replies 123
  • Views 51.1k
  • RussPitcher
    RussPitcher
    If it helps anyone I created a 3d-printed wireless charger holder for my 2021 TSI IV front tray and iPhone.  I made two versions, one for an eono charger and one for an Apple MagSafe charger. Works a
  • I'll try to make more chargers in a couple of weeks.. It would be interesting to compare my version with the original.
  • PITBULL4X4
    PITBULL4X4
    Neither is making out something is a issue when it’s not 🤷‍♂️ Skodamk4 suggests that not being able to turn it off is a problem when it is not. Can’t see why you’d want/need to turn the charger off.
How much is it, out of interest? I am on the South coast however, so unlikely to take you up on it I'm afraid!
If you'd like to send us your VIN then we can quote it for you, don't worry if you don't plan to go ahead - it's something we need to price up anyway 🙂
When I get it I will drop you a PM - car is being delivered to us on Saturday. I do remember the option cost was (I thought) ridiculously high at around £200, especially given there is a USB port right there and you can buy decent off the shelf wireless chargers for £20 or so, so not sure how much I would be willing to spend on it.
On 31/01/2022 at 12:01, Mattster21 said:
You can put me down as interested. I can't remember the exact figure, but it was something around £200 for the wireless charging option which I thought was a little spendy for what is effectively a £20 wireless charging pad. Is there any way you can let me know when these are available again?
Let me know and I’ll be buying one!
Do you know how much power the USB in the front can supply? Wondering how fast the wireless charging will be..
Please post up here when you have more available!
Bare in mind the original will have a designated position on the fusebox, and will integrate with the infotainment system. You also have the option to add an antenna & amplifier to allow it to boost your telephone signal 👌
I don’t think I’ve ever felt any need to boost my phone signal!
I don’t know about lower models but my SEL integrates the phone very well into the infotainment already wirelessly.
I forgot to say, I really like how you’ve made yours, really neatly made. One question though- does it matter which side the USB-C sockets are on? Mine are on the left but mine is a RHD.
I have 2 versions , for RHD - UK, Malta, etc(1 picture), LHD - Europe, Russia, etc(2 picture).
now still waiting for parts..
My Witrn U3 usb tester shows 5V 1A in my european version of octavia.
Anyone got ideas how to disable the original wireless charger? One way would be to remove its fuse, but it has USB-C ports on the same fuse.
One way would be to leave the fuse in place, "lift" the plastic tray that includes the wireless charger and simply disconnect the cable on the back. (I'm assuming it's a connector, not a soldered cable)
For the dismantling instructions see the Skoda service manuals - there was a link to all of those somewhere on this forum.
Let me know if you don't find it.
Well actually i'm getting my car maybe in march :) I'm not good at searching or looking at manuals. I almost need someone to virtually hold my hand on how to disassemble the charger pad.
I'd be glad if you could give me more guidance on this one.
Just interested - why would you want to disconnect it?
I've done this in my Superb....
PXL_20220207_091638618.thumb.jpg.f8029678a33b68b10c35e990e2642b95.jpgPXL_20220207_091609020.thumb.jpg.c58cc5bf51b9e7197024f5a2dfca592c.jpgPXL_20220207_091548275.thumb.jpg.4f64792f632b55ee7fe51233ae8a291e.jpgPXL_20220207_091533888.thumb.jpg.6ecd2ba4f583ad3a25ba4e58b4dee853.jpg
Well my drivings are mostly short. It's more bad for the phone to charge it for 15minutes. Rather not charge it at all than charge it for few percents. Wireless charging warms up the phone quite alot which makes the battery decade faster.
I'll rather use USB-C when i need to charge.
Nice, except Octavia's dont have usb-c in the hugebox.
It's USB A to USB C, but I wasn't sure if the Octy even has power in the arm rest/jumbo box thingy.
I think I’d rather just leave it on my pocket or put it in another place than take my dash apart to disconnect it. You might want to use it on longer journeys anyway, or a passenger can use it to reduce the cables trailing around.
Or simply add a flat "spacer" between the charging pad and your phone - such as an anti-slip rubber mat, only a few mm thick. At that distance the phone will not charge. When U want to use it, simply remove the spacer and charge...
I rarely keep my phone in my pocket. Need to change tracks etc quite often. I usually keep my car under the center console, so the place is perfect but the wireless charger is useless for me.
For now the best option for me, is to just have something there to block the charging.
You would change the tracks using the car controls anyway.
Not if i want to select specific tracks or fast forward them
Does it really matter if you’re only in the car for 15mins as you have said? It’s barely 4 songs, or maybe one if it’s Pink Floyd. 😂😂
