Electrics on right hand side
Wonder if any one can help , 2013 Skoda superb  est, Yesterday I couldn’t open  windows from the drivers window control  the remote mirror button doesn’t work either  and the remote key  won’t lock the drivers door  and  is the  passenger door , the rear (off side)  window button doesn’t either , although the n/s widows work and the doors  lock as does the rear door ... any suggestions what I’m looking at  here please?
I would say definitely broken wires in between driver's door and body I've just gone through this on both my front doors wiring it's not that bad a job
Ah thank you , I’ll take a look , where were yours specifically broken please ? Was it a mission to take apart ?
cheers Pete
You have to pull the rubber gaitor away from the body of the car you just press on the top of the rubber and it pops off easy when you pull it back you might not see any because they might be further in the door and you have to take the door card off and pull the harness through to have a proper look
Ah ok , I’ll take a look today and  thank you for taking the time , I really appreciate it :)
pete
