Accidentally Reset Brakes Module OBD11
Hello! I accidentally did a reset of my brakes from Basic settings within OBD11. Replaced the brake pads and did not think the coding threw and I messed up. Atm I have several fault codes due to the Brake Module not coded correctly.
What I have tried to do:
Tried going back to my History and god the full Value of the Long Coding part so I have the full "Before value"
- But when trying to replace all the 000000 HEX in the long coding - with my value it will not accept the coding when trying to apply it the Security code access window popup but it will not accept any of the logins.
- Tried resetting and did a basic settings part of the Steering Assistance, with a bit of google search but then when going back to the brake module and putting in the brake value it still wont work.
How can I fix this problem? Im a bit out of ideas atm, so any help will be very helpful.
Thanks in advanced
