All Weather tyres and Summer tyres
49 minutes ago, farty said:
You did not read my post carefully.  I'm on about the SIZE designation 225/40YR18.  I asked why this number has a Y in the middle.  The previous explanation covered a Z.
This is a presentation issue on the website, having filtered to correct size 225/40 R18, they are including the 92Y.  As already discussed the letters are max speed.   The 92 is a load weight rating. (92 is 630kg), so no wheel should carry more than that fully loaded (might be easier to think of it as 1260kg max per axle).
Table of weights here
https://www.ctyres.co.uk/general/load-index
Edited by SurreyJohn
  • Replies 178
  • Views 17.2k
  • As said when to fit your winter     ( not snow) tyres really depends on location. As a rough rule of thumb, I normally swap mine over around the clock change at the end of this month and swap bac
  • It's six weeks away man!  Unless you are driving overnight the daytime road surface temps will be much higher then.
  • Don't mix all-season and 'normal' tyres.  If you have to drive in snow, the car could spin.  Goodyear all-seasons are very well reviewed.   All-season plus summer tyres is even worse.
Is it still the case that the speed rating is the 10 minutes a tyre can last without it self destructing, so 11 minutes on a Y at the rated max might get interesting (not on a Superb obv.)
I'd have to use premium diesel to get my Superb elegance estate up to 186 MPH :-)
I have V rated winter tyres on to slip along at 70 mph when weather conditions allows and the Max speed is only 93 mph anyway.
