Felicia voltage gauge
On 08/09/2021 at 08:37, Papez said:
They did, the "INT" position in fusebox is for rear intermittent relay.
Could you please tell me how to operate the rear wiper on a 1993 Škoda Forman LX? When I got the car, wiper lever was too loose it was turning on itself with gravity. I've replaced it with a brand new wiper lever. Original part from Czech Republic. Rear window wiper is not working too. I've learned that, it's a chronic problem because of some plastic cogs in the rear wiper mechanism. They sell rear wiper cogs in local stores but before attempting any repair I have to diagnose the exact problem. I couldn't test the rear wiper because I don't know how to turn it on. 😟 (Front and rear window washers are working.)
@R_Blue in Felicia, wiper switch can be pushed forward in two positions, first is rear wiper, second is wiper+washer. I'm not sure if it's same in the Favorit, as wiring is a bit different there.
23 hours ago, R_Blue said:
With TC6 and your own modifications, you won't need much of this project's benefits. This projects main focus is pre-1993 Fav. cars. They don't have a tachometer too. I recommend people with old models to take a copy of the web sites contents before it vanishes from internet. It's a very valuable project both for car enthusiasts and electronic hobbyists. The Czechs really love their cars and I appreciate that.
In the beginning i saw those 2 projects but i hesitate to buy any of them.
It's great for the Czechs or the Polish to do that, it's the same in USA especially at South were people restore-modify and drive daily cars from '70's 60's even 50's. I highly respect those guys and it's an inspiration.
Do you like old style digital dashboards? Could you believe Lada Samara had this dashboard with a separate trip computer in 1989?
Amazing, i didn't knew that.
Thank you! This really helped me.
Pull up: Front wiper first speed
Pull up second stage: Front wiper second speed
Push the lever inwards: Windshield wash.
Pull the lever to yourself first stage: Rear wiper
Pull the lever to yourself second stage: Rear wiper + wash
I repaired the rear wiper motor and it's working now. :)
Those projects involves cutting that cover on the dashboard. I didn't like workmanship in the second. TC-6 is looking sleek. If it fails in the future, you could use its cover and buttons for a DIY project like those above.
Cheers to that! 🍻
