Rattle from rear...
Hi, over the last few months I've begun to notice a rattle from the back - perhaps the rear wheel drivers side.
I haven't investigated yet, but I suspect worn bushes or something similar.
I have a Haynes manual for the mk1. Is it likely to be a similar detail or will I need a new manual?
Thanks for any advice.
What sort of rattle?  If it's a light tinny rattle we've had a few of those and they've been exhaust heat shields or brake disc splash guards working loose
Thanks, well the heat shields are a bit loose, but what i hear is a bit heavier, clunkier.
Just wondering if the MK1 is similar to MK2 in terms of suspension/bushes set up.
Edited by Regsmyth
Many years ago now I had a more of a  light donk than a rattle from the back of mine, couldn't find anything with any notable wear in, but took a punt on the anti roll bar drop links which had the smallest amount of wear and that seemed to do the trick.
Well I finally decided to have a closer look.
To my inexperienced eye, the bushes in photo 1,2&3 look worn.
There is also the ARB bush, but I couldn't get a good photo.
The rear drop links were also difficult to see.
Are there any wiggle/lever test I can do to identify bits that might need replacing?
  • 10 months later...
The other "humming" thread reminded me that I should update this thread.
I went for a drive with a mate in the boot trying to locate the rattle noise. He concluded it would be the drop links.
I changed them - no change.
Then I touched the rear strut cover - and found it was loose and had dropped down from the bump stop.
Wedged it back up with a bit of old sponge, and the rattle was gone!
The strut cover had dropped down because the strut had leaked and rotted the bump stop.
All sorted now though.
