Octavia 245 vs Superb 280 Engine Comparison
MTwedVRS
Recommended Posts
Hi all,
Maybe this has been covered before but I can't find any topics.... what are the differences in the Engines between the Octavia vrs 245 and superb 272/280?
I appreciate they are the same block, but what else is different?
thanks
Matt
Link to comment
Share on other sites
245PS/370Nm remaps to 302PS/450Nm@1750rpm
https://www.dtintecno.de/cars/2-0-tsi-rs-180-kw-245-ps:14432
280PS/350Nm remaps to 332PS/430Nm@1900rpm
https://www.dtintecno.de/cars/2-0-tsi-206-kw-280-ps:14441
It looks like the remapped 245PS engine has the best torque. Not only 20Nm more, but produced from 150rpm lower down the rev range. However, you would need to see the torque curve of both remapped engines to get the full picture.
So according to dtintecno, the remapped 245PS engine has a whopping 100Nm more torque than the standard 280Nm engine.
Edited by Carlston
Link to comment
I think the OP was asking about internals and variation in turbo, vice remap Top Trumps. My 220 VRS stage 1 torque was 480NM. The remap pub bragging rights will depend upon each mapper. In reality it’s how effective that translates to actual road use for most of us.
Edited by Redboy
Spellchecker again!
Link to comment
Very interesting figures... i plan on remapping my 245 early next year when the weather gets a bit better, so for 'fun factor' I'm sure the 245 will slightly surpass the superb, just by the fact its lighter and has a more sport focussed suspension setup.
My original question was more around the components as I wondered how strong the 245 was and how far you go with mods until it breaks! But your answer is very useful.
Yes i was referring to components I should have been more specific :D but after all I am asking to understand the tunability of the engine so understanding the remap is also very useful!
Link to comment
There are lots of remap threads on here. Common figures for Stage 1 for TSI 220-245 are about 300-310 BHP, with the 280/272 around 350 Bhp. The only difficulty for the Octavia will be putting the power down efficiently at lights and roundabouts. Once you're rolling it is a lot of fun and quick.
  • Thanks 1
Link to comment
Yes i was referring to components I should have been more specific :D but after all I am asking to understand the tuneability of the engine so understanding the remap is also very useful!
Looking at what both engines will remap to gives an idea of whether the hardware differences are big or small. With the difference in the remapped power outputs of the 245PS and 280PS engines being small, it would suggest that the hardware differences are also small.
Another example is the 90PS and 110PS 1.2TSI engines. These engines both remap to about the same power output which would suggest that they have the same hardware. Both engines only remap to around 100PS to 105PS per litre of engine capacity, which would suggest the hardware on these engines is quite modest. However, modest hardware can sometimes give good low down power and driveability.
Edited by Carlston
  • Thanks 1
Link to comment
Hi all,
thanks
Matt
This might help, it appears to be a defined Golf R engine ...unless the 245 is also DNU engine?
  • Thanks 1
Link to comment
The 245 has a smaller IS20 turbo which spools up faster and earlier than the bigger IS38 9shared with the Golf R) of the 272/280. My standard 245 had 400nm at 2,600rpm whereas my standard 272 had 269nm at 4,500rpm and the 272 needed revving to almost 6,000rpm to get the best from it whereas the 245 gave its best performance upto 5,000rpm. The stage 1 245 gave 302bhp and 467nm and my stage 1 272 gave 360bhp and 514nm. When I took the 245 to stage 2 it produced 336bhp and 517nm but was a handful particularly on a wet road. I remember it spinning the front tyres at a barely believeable 77mpg in 3rd gear which is dangerous. The safer, better car is the 272/280 which is a more practical Golf R and a Golf R is better than a Golf GTi. They share the same brakes 340mm vented front discs and 310mm vented rear discs but the 245 was almost 300kg lighter so stopped better (1370kg versus 1,660kg). 4WD traction was very impressive on the 272 whereas the FWD 245 struggled to put its power down. Steering probably nicer and more direct on the 245 and both cornered well with the edge going to the lighter 245. Did 29,000 miles with a manual clutch on the 245 and just over 9,000 miles in the 7 speed DSG 272. Both averaged 40mpg which was impressive the 245 had a maximum range of 530 miles from the 50 litre tank and the 272 a maximum range of 720 miles from the 66 litre tank.
  • Like 4
Link to comment
Some internals are strengthened in the 272/280 unit. Pistons, exhaust valves and seats. Different cylinder head and cams. Fuel delivery system is uprated, including injectors. I’m sure there’s other bits but  that’s probably some of the main ones.
In the Golfs, the is38 unit doesn’t seem to suffer from the same end float I’ve seen in the is20 unit, and the same goes for timing chain issues.
Edited by UndertheRadar
Clarification
  • Like 1
Link to comment
  • 3 months later...
Hi all,
thanks
Matt
Not seen anyone mention this in this thread, but afaik, the 280 doesn't have FSI and I thought the 245 did, but I'm not sure.
Perhaps someone who's familiar with the 245 can confirm?
Link to comment
  • 2 years later...
I have a stock 2016 Superb and I never see 40mpg average on my car. Also when I read reports from Stage 3 Octavia VRS owners even lower consumption numbers, I start thing maybe my car is having issues which it doesn't have any errors.
where should I look how should I diagnose it? btw: Skoda service mostly says it is in good condition :/
Link to comment
me too have seen lot better numbers there in BS forum,
but not in real life - MY23 280ps at it's first 6k Kms
l/100km     MPG.uk
12,7 22,3
17,8 15,9
15,9 17,8
9,9 28,6
9,4 30,0
16,2 17,4
8,7 32,6
12,3 22,9
9,6 29,3
15,9 17,8
8,5 33,4
8,1 34,7
9,3 30,3
8,7 32,6
  • Like 1
  • Haha 1
Link to comment
l/100km     MPG.uk
12,7 22,3
17,8 15,9
15,9 17,8
9,9 28,6
9,4 30,0
16,2 17,4
8,7 32,6
12,3 22,9
9,6 29,3
15,9 17,8
8,5 33,4
8,1 34,7
9,3 30,3
8,7 32,6
If it is not out of the city, I don't see sub 10lt/100km consumption numbers. I think I might have another issues but in anyway. How come stage 3 octavia with same engine can consume 6lt/100km and ours can't.
Link to comment
Interesting thread. I didn't think there would be much in it between the lumps except for turbo/fueling.
For the MPG my stock 220 DSG gets 33-35 commuting over a 5 mile drive in the summer. I can quite easily knock 10mpg off that in the winter, but alot of that is short journeys. Summer motorway journeys, best I had was 39 which was to Goodwood from Plymouth and back with some foot down fun and 3 people in total in the car. Winter I'd see 35ish.
Lots of variables with people's own individual driving styles, journeys, weather conditions, tyre pressures, etc. I've learnt not to get too caught up with what others are getting and focus on if the car feels right. Generally if you know your car, you'll know if it feels like it's working properly. If MPG is drastically out then you can judge it's probably got something wrong.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
