MY17 Superb Retrofitted with Direct TPMS
Is the control unit still responding via diagnostics? If not, buy an OEM part.
  • Replies 156
  • Views 39.7k
  • It depends what system your wife's car has. Indirect systems don't have physical pressure sensors, instead they rely on rotational differences between the wheels (via the ABS sensors) so would just ne
  • We can now, thank feck
  • I'll post up the exact VCDS/OBDEleven coding steps shortly. I'll also post up the link that allows u to create the RDX parameter file, to b loaded via VCP/ODIS.
Check your sensors. If you can connect normaly to 55 module, your sensors died. Aswell had problems with faulty module and sensors from ali since get one which works
I made them check by the tire guy with the instrument that activates them and he showed me they’re active; making a diagnosis with Odis the result was “system turned off” so now I have to understand how to turning it on again!
Not properly coded if doesn't work after mib change
The MIB has nothing to do with the functionality. Even with the MIB removed, it still works perfectly fine for me.
That’s the point: until last week I was able to see the pressure values as on the Amundsen, then on rear wheels pressure was lower, after restoring 2/3 days later I got the message I posted above. Do I have to code again from beginning or any other idea/proposal?
Any other present error codes in 5F or 65 module?
Recently Browsing 2
