Virtual Pedal Retrofit
On 02/01/2022 at 17:58, ApertureS said:
Ive ordered a genuine sensor aerial and im gonna mount that instead of an aliexpress special, then i will try your coding when it turns up and let you know. Thanks!!!!
HI, Glade you have successfully make it work, Where and how much cost you geniune device?
So for resume
You code the keysys and the virtual pedal only?
  • Replies 56
  • Views 34.6k
  • All working finally, with kick to open and kick to close
  • Thanks so much to @JR RS for this picture.     so helpful.   Now I just need to figure out where the wires should enter the boot, and where the little 'connector bloc
  • All the wiring for PDC sensors and virtual pedal connectors come up to this one plug, which connects to the CANBUS wiring that runs into the car body under the master (right side) BSM radar.
On 03/05/2021 at 23:29, AlVal said:
Just to correct my earlier post about the wiring to KESSY pins, it should be pins 2 and 16 on KESSY.
Also the holder bracket I bought from skoda to hold the module doesn't work because its designed for a skoda module, and the one in the Chinese kit is from a passat, must be a different shape.
Can You send us all steps with coding the virtual pedal?
so ApertureS how you solved 221445 - Sensor for rear lid/hatch opening - No calibration/Basic settings fault? just by changing sensors?
hi guys! I'm struggling to start Easy Go! My trunk lid controller is:
SW: 5Q0 959 107 AB HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0272
I bought the entire set 565 962 235 E which included the 5NA962243B controller plus two glued-in antennas. I installed everything and connected it to the Kessy PIN 2 and 16
I did the coding (Kick-to-Open/Kick-to-Close Active etc.) in the 5th module!
I tested: ENG246994-Verdecksteuergerät-virtuells_pedal_version
version_1_2 - For most older installations (up to approx. 2020)
version_3 - For newer models/sensors after 2020 - a different way of communication
I activated all Virtual Pedal - Active options
It doesn't work and I have no errors and it doesn't open the flap with my foot!
Colleagues, can someone help with this topic?
Please, help me guys!
Try gluing the black strip, i.e. the sensor cable, to the top edge, right past the tow bar cutout. It's possible that the sensor won't respond if it's positioned down there. OEM doesn't do that either. Or swap both: black on the front, red on the back.
I have this error, everything is connected correctly, I've checked it twice. The sensor module in the bumper is new.
Address 05: Start Permission (J518) Label file:| 5Q0-959-435.clb
Component code SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
1 error found:
221700 - Rear cover opening sensor
B1303 31 [10001001] - No signal
MIL on - Confirmed - Tested since error codes were cleared
Freeze frame:
Error priority: 2
Error frequency: 1
Internal error counter: 79
Mileage: 178847 km
Date: 2025.06.09
Time: 18:31:49
Terminal_15_Kessy_specified_value: ON
Terminal_15_Kessy_actual_value: ON
Terminal_15_central electric_actual_value: ON
Terminal_15red_Kessy_specified_value: ON
Terminal_15red_Kessy_actual_value: ON
Terminal_S_Kessy_specified_value: ON
Terminal_S_central electric_actual_value: ON
Terminal_50_Kessy_specified_value: OFF
Terminal_50_Kessy_actual_value: OFF
ZAT_pressed: OFF
Range lever position: park: Unlocked and locked
Query active: Condition not met
Steering column lock unlock: Condition not met
Immobilizer unlock: Condition not met
No active fault mode: Condition met
Key signature validity: Condition met
Control Module Voltage: 12.136 V
Driver Information: Key Position Recall: Service: Disabled
Driver Information: Vehicle Rollback Warning: Disabled
Driver Information: Emergency Stop: Disabled
Internal_key_position: no_message
Driver Information: Comfort System Disabled: Disabled
Vehicle Speed: 0.0 km/h
Engine Speed: 0.0 /min
Vehicle Lock Status: Vehicle Unlocked
Inside Zoom: Disabled
Inside Start: Disabled
Outside Zoom: Disabled
Outside Start: Disabled
Outside Door Handle Actuator: Disabled
Code Information: Coded
Inside Start: Disabled inactive
External zoom: inactive
External start: inactive
Exterior door handle linkage mechanism: inactive
Code information: Coded
Interior zoom: inactive
Interior start: inactive
Exterior zoom: inactive
Exterior start: inactive
Driver door: Closed
Passenger door: Closed
Rear left door: Closed
Rear right door: Closed
Active_LF_scans: Init.
Sensor ID 1 identification: status: No response
Sensor ID 2 identification: status: No response
Sensor ID 3 identification: status: No response
Sensor ID 4 identification: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Hi I’ve a 2024 mk3 superb combi in style spec (ireland) it’s got electric tailgate with keyfob and button by the gear selector for opening the powered boot. I’m unsure if this has virtual pedal I watched a vague Skoda YouTube video and followed instructions but the option doesn’t seem to be in the menu.
Thanks in advance.
