OEM ambient lighting retrofit
@SashaGrace
Hello Sasha and company,
Please, I have a split car and I would like advice on where to connect the 3 wires.
1 - connect the red wire to position No. 8 and put a 7.5A fuse there
2 - On BMC to pin 29 connector C violet yellow
3 - I will put the brown one to the fuse box on the screw
What I don't know
4 - to which pin and to which connector should I connect the red and white wire in the RJ door or in the inter-door harness
5 - to which pin and to which connector should I connect the purple-yellow wire in the RJ door or in the door harness
6 - I have the brown wire of the frame mounted in the door, I'll just connect it
I am adding a few photos.
  • Replies 61
  • Views 46.7k
  • SashaGrace
    SashaGrace
    Do you have the correct BCM? If not, that’ll need changing too. 5Q0937084CG or DD is good along with some others but 084CF is no good. If you have Pin 29 on connector C you are good. Floor lights are
  • Woodpeckercz
    Woodpeckercz
    Would you be able to write up how to do this? It looks amazing and I need it
  • @SashaGrace i second this. would love to do this and maybe a VC to my 2016 mk3. but dont know here to start with parts, or finding if in need a diff bcm ect.
Hi guys I just bought oem lights from Amazon I connected them to existing Footwell lights plus and minus and to existing pin 29 and don't work. Can you tell me please if I connect those lights just to plus and minus should they light up as white? Or it need to be 3rd cable connected to it to work . At the moment I don't know they working or not I don't know how to check . One more thing I have ambient lights in doors already and I coded radio I see colours in radio .
Small update in my case . I have ordered one genuine light and nothing works.
Show us what you’ve done and what is not working and what tests you have carried out?
if it’s as above and only got a power and ground it won’t do anything. It needs the lin wire and the correct signals and coding.
it is a smart light with a micro controller that needs to be told what to do, can’t just be powered up
3 pins connected brown -, red +, violet to pin 29 strange thing is , there is something connected already . For incase I use coding like mentioned before nothing happened my module ending cq and should be fine
One more thing I can change colours on radio in doors and Footwell. In doors it's changing but footwell don't work at all
Hello,
Can anyone help with the correct purpose for each wire?
Wich one is for LIN, + and - ?
Can I light them up without the LIN bus being connected?
Thanks!
On 17/10/2023 at 16:19, Andrei1496 said:
Hello,
Thanks!
LIN is purple
yellow is power
black is ground
Thanks!😁
On 07/05/2023 at 19:14, Joco776 said:
@SashaGrace
What I don't know
Did you found answers to your questions?
@Andrej1986 Yes. In the end I had to figure it out myself, no one here gave me advice🫤
Maybe you can post here everything you done step by step i have now door cards with ambient lights and absolutely have no clue what to do next 😀
Looks like not so many people done it i can't find any info about it in internet, looks like you have 2016 superb, same as me, how to find out what BCM i have? And where i need to connect cables from ambient light i already bought connectros, i have some knowledge how everything works but it is something new for me.
@Andrej1986 Hello. I have to find my dates and I will write you at the weekend, I can't do it right now.
Thank you, that would be perfect.
Hi, maybe you found any info ? Thank you.
On 25/05/2021 at 00:34, SashaGrace said:
Do you have the correct BCM? If not, that’ll need changing too. 5Q0937084CG or DD is good along with some others but 084CF is no good. If you have Pin 29 on connector C you are good. Floor lights are a must too IMO.
I've 5Q0937084DK is good FOR AMBIENT LIGHTING?
Edited by Unecc
@Unecc 5Q0937084DK it does not have pin C29
@Andrej1986 What is your BCM number?
Yeah i' m installing aftermarket ambient lighting. Please can u tell me pin for dc 12v that you use? I m going crazy
As per your other thread, it depends what your kit needs.
OEM ambient lighting takes a permanent live feed from fuse 8:
found lots of LIN lights on the web with some searching.
8W0 947 415s for the footwells
8W0 919 390s for the doors
then 7p6 919 390 for the charger port... how can i find out which connectors are used? Which diagram on say lll parts?
the kodiaq already has ambient in the doors, I'm assuming the BCM can handle this, I will take a look tomorrow and see if I can connect to it cleanly.
On 02/11/2023 at 07:19, ApertureS said:
LIN is purple
yellow is power
black is ground
@ApertureS actually LIN is yellow, 12V is purple and GND is black
  • 8 months later...
Hey, can you send me the lightning that you have on the foot would like to get one? i want to do ambient lightning too, i already have it on my doors but i want to do another one on the dashboard but not sure how to do it.  Also in vcds in section 09- cent.electronics i have some options greyed out such as 10-adaptations i see that you have 30 led colors but i cant get into that section via my vcds. i have kodiaq 2021
