Accelerator pedal idle issue
Hi, I found a few links on Briskoda about 'sticky throttle/accelerator pedal'
Lifting the accelerator pedal with foot under it does lower the revs from 1000 back to 800.
It is unclear how to repair?
- Someone has put an 'English spring' - drilling a small hole on the pedal and attaching spring to retract the pedal (saves lifting with foot).
- Replacement with second hand units or new - Apparently fit and forget. I have replaced brake pedal switch some years ago on same car.
- Throttle body in engine bay (is this the anti shudder valve ASV?) near EGR
- Lubricating (someone suggested silicone - I wouldn't use silicone - it is an insulator and will prevent electrical contact) pedal.
Will a new pedal solve this issue and any ideas on a dealer sourced part cost? Suggestions (guide)?
It does sound like the pedal unit is faulty.
Yep  Fabia 1 VRS 1.9 of turbo
Thanks for that. I will give dealer a call.
