Maxidot not communicating with head unit, amundsun
Hi my girlfriend has a 14 plate rapid spaceback.
I've installed an Amundsen plus. It all went well untill the maps froze, I've managed to fix this now with a new antenna.
However while trying to figure out why it wasn't working I disconnected the fuse for an hour to see if it would hard reset to fix the problem, but now there is no communication to the maxidot display.
It's showing the control module is incorrectly coded:
19 Gateway
    System description: GW-K-CAN TP20
    Software number: 6N0909901
    Software version: 0411
    Hardware number: 6R0937087
    Hardware version: H34
    Long coding: 932300
    Trouble codes:
        01044 - Control module incorrectly coded
            static
The code for the head unit is:
37 Navigation
    System description: RNS315-EU
    Software number: 3T0035192J
    Software version: 0319
    Hardware number: 3T0035192J
    Hardware version: H55
    Serial number: SKZAZ2M9296444
    ODX name: EV_RNS315EUV2UDS
    ODX version: 001705
    Long coding: 0400041104062B0001000002
    Trouble codes:
        B106613 - Left rear treble speaker Open circuit
            static
        B106813 - Right rear treble speaker Open circuit
            static
        B105411 - GPS antenna Short circuit to ground
            static
        B105313 - GSM antenna Open circuit
            static
        B104813 - Telephone microphone Open circuit
            static
        U101400 - Control module incorrectly coded
            static
Does anyone if there is an issue with this coding?
