Last job on list.
1 hour ago, DieselMonte said:
When I did my bushes I put the Wishbones into the consoles and put that into the subframe
That might be your solution here then Stewart, 'cos that way you can get a better angle to start them going in, without the subframe in the way, by the look of it.
Just be aware that front alignment will be affected if the consoles don't get refitted to the chassis in the same position as they were when they came off.
There's 5mm of slop in the two mounting holes of each console-to-chassis.
  • Replies 80
  • Views 9.3k
  • The main issues with the M12 bolts in the console is not the bolts themselves, the threads can suffers from some sort of corrosion (galvanic corrosion) between the alloy console and the steel bolt, me
  • I left the consoles on when I did mine and instead of cutting the bushes out with a hacksaw I heated the console bush housings with a blow torch and it softened the bush outer plastic shells enough to
  • sepulchrave
    sepulchrave
    I used Cupra bushes on my first Fabia, horrible to fit but good performance. I used PSB on this Fabia, easy to fit, same performance. Powerflex are just as good and just as easy to fit but m
I assembled mine on the bench that way, but iirc when I removed the old ones I had to remove one stuck to the console.
If it can be removed like that then it stands to reason it can go in that way.
Found a pic of it in my project thread.
That's how it came out of the car.
20220517_184425.thumb.jpg.d2e1b599aaa3bfa728b3f92e7251e14e.jpg.d4cbba797f76a20f63e943f606399ea6.jpg
Good quality washing up liquid is extremely slippery. You could try some of that on the pins. I've previously used it with good results.
Yeah tried the washing up liquid I was using silicon spray as well slippy as chit lol I've got a heavy duty ratchet strap coming tomorrow hopefully that will give it the extra force it needs I dont really want to go down the route of stripping out subframe if possible.
Yeah, ratchet strap should do it.
Hi meant to update and say the hd ratchet strap did the trick and all sorted now thanks guys :)
