problem at low revs 1100-1200, 1.9 SDI ASY
thanks
  • Replies 51
  • Views 8.1k
  • Titanium_Man
    Titanium_Man
    I would say it looks like Google translate is being used, @Pete_Ex-Wino
  • Breezy_Pete
    Breezy_Pete
    Is that under a front seat? Yellow connectors are airbag related I think  so nothing to do with engine running.
  • The Accelerometer is only there for the side impact detection for the airbag system absolutely nothing to do with the engine
On 25/04/2022 at 23:16, sepulchrave said:
It has an ECU, it must have a MAP or a MAF, I know it has no turbo but that doesn't mean anything for the electronics.
No AMM/MAF or MAP but it does have an Inlet Air Temp Sender G72 and a Fuel Temperature Sensor G81 and the G81 can give incorrect readings, does the MVB value make sense?
both sensors have been replaced
no change
there are no errors in the ECU
can this sensor be to blame
Sensors replaced but is resistance /continuity OK. esp at coonectors?
can this sensor affect the engine discount
I think you're right, Pete.
there are two connectors one for the airbags and one for the side acceleration
not related, can the acceleration one cause problems
separate cables are, not connected, but in one place
when the car heats up to 90 degrees, it starts working like clockwork, why cold doesn't work well
Maybe the compression of (one or more of) the cylinders is low, so it struggles to ignite the mixture when the engine metalwork is cold?
the car starts in the cold immediately without any problems, without smoke
It was just an idea. 🙂
Why do you post in such a big text size?
Edited by Pete_Ex-Wino
from the computer is the size of the text, now I will correct it
да
yes
Ah, I see. :)
i thought it was just me seeing massive text :D
have you checked all the vacuum and air lines for any spilts or cuts? it could be something is loose when cold and letting unmetered air into the mix but once it heats up the expansion seals the hole/gap.
only on the go at 1100-1200 rpm cold works poorly, as it heats up there is no problem. if it does not move it works well cold
all vacuum hoses are checked, the intake manifold is cleaned, when you turn off the air temperature sensor the engine starts to work well
