Skoda Superb Combi 2.0 TDI 4x4 140kw L&K Business Edition - 2018
Oh damn...On cold start, Superb started act weird and revs jumping + vibration all over the car. Done video about the current situation. It ends about few minutes.
On ordinary maintenance in march, they also scanned car for errors and on invoice there is info "EGR valve random errors on memory" - but then I didnt noticed any abnormal behavior until now...
What to expect ?
Edited by superbuser35
  • Replies 50
  • Views 12.9k
  • superbuser35
    superbuser35
  • Hello SU35    That's exactly what I did, although ten years before you in 2012.  Went from a HOT 9-5 Aero to a V6TDI Mk1 Superb.  I went to see it with my Dad, and said to him 'This is it'!
  • superbuser35
    superbuser35
    Updated infotainment: MHI2_ER_SKG13_P4518 1240  -->  MHI2_ER_SKG13_P4526 1440
Okay...I hope now is the last problem solved :)
05.04.23 - During a cold start, the machine tended to cough and revs jupmped. Diagnostics were performed and the glow plug control relay was replaced, OEM: 04L 907 282 B
02.04.23 - I succumbed to the temptation and finally bought OBD Eleven - so that I could check the machine with my own hands if it seems a little sour. I have played with it a bit and I would say that the 60€ is worth it :)
The machine has been ticking so far on the OEM battery. Battery Varta 7P0915105 68Ah 380A.
On the minus terminal of the battery, information that the production date is December 2018
However, I decided to change the battery and chose EXIDE EK720 72 Ah 760 A
During the purchase, I investigated whether it is possible to get a battery whose production time is not very far. The code on the new battery was E811-339, so now I needed to understand, when the battery was manufactured.
Exide made changes in reading the year of manufacture of the battery to 2021, and you have to look at the last three numbers, which is 339 at the moment, which means:
first number 3 = year of production, i.e. 2023
39 = March
Basically I got a battery that had just stepped off the line :D
The battery was changed today and also deactivated start-stop.
In the meantime, the weather was getting so summery that, sitting inside, you wanted to blow a little cooler air. To my surprise, it was lukewarm. The machine uses a newer type of substance, R-1234YF.
The whole process took 45 minutes on the device, 0.460 kg of refrigerant was loaded and the bill was €95. The majority of places charge at least €120. The agency charges €185 for the same work.
Time-to-time, when scanning with OBDEleven I get NOx error: P20EE00 - SCR NOx Catalyst Efficiency Below Threshold Bank 1 Catalyst 1 Intermittent
No dash warning and car driver normally.
My question is - where to begin to solve this error ?
Bought CTEK Battery Sense to have an overview of the battery. Install and pair with the phone was really easy!
How hard was it to update the MIB2 unit?
There is no issues with mine, but it would b nice to update it.
This is mine now:-
Software number: 3V0035045D
Software version: 0942
Hardware number: 3V0035045
Hardware version: H50
It wasn't hard at all and went faster than I thought it would take.
After update scanned with OBD11 and it found error, but can't remember, what exactly it was, but got fixed by changing parameters.
Today was the 1st year of owning a Superb. Overall satisfaction is high. It really is a good car!
Annual mileage came 11500 km and long-time average on screen is 5.1 L/100km.
Total mileage: 116 927 km.
So which type of shock absorbers do you have,
standard, or software adjustable (DCC)?
I have DCC: ECO, Comfort, Normal, Sport, Individual
Brake fluid and fuel filter were changed today.
New brake fluid is TRW and fuel filter: 5Q0127177 MANN-FILTER PU 8028
mileage: 117 641 km
  • 6 months later...
23.01.24 - Haldex 5 oil change and haldex pump screen cleaning.
mileage: 123 915 km
Spring is no longer behind the mountains and quietly preparing.
• Air filter: OEM code: 5Q0129620C - MANN-FILTER C 30 004 / cold climate filter - €12.61
• Cabin filter: OEM code: 5Q0819669 - MANN-FILTER FP 26 009 - €15.69
At the moment, behind and in front are VALEO wipers, but for a change, in the spring, when the snow has melted, they will be replaced by Bosch:
• Front: 3 397 007 863 / BOSCH Aerotwin A863S - €17.65
• Want: 3 397 008 998 / BOSCH Aerotwin A 403 H - €7.75
Total: €53.7
• Motor oil VW504 00/507 00 Mobil Super 3000 Formula V 5W30 5L - canister is €40
Filters, wipers and oil in total: €93.7
Any ideas what should I do with my car - any replacement or tuning ? Little bit boring 😛
Had the Superb L&K regular maintenance:
* undercarriage and brake system inspection - everything OK
* engine oil change (VW504 00/507 00 Mobil Super 3000 Formula V 5W30)
* Oil filter (MANN)
* Oil cap, oil valve cover
mileage: 125 319 km
The air and cabin filter was replaced today:
A nice 20 minutes of tinkering.
Mileage: 126814 km
Replaced Superb MK3 wipers:
Was:
Front: Valeo Silencio VF387 (574707)
Back: Valeo Silencio Rear VR267
Now:
• Back: 3 397 008 998 / BOSCH Aerotwin A 403 H
It's been a while since I last posted and I thought I'd write down what I've done in the meantime:
06.03.2025: Regular engine oil change + technical inspection
Mileage: 137,595 km
  • Engine oil VW504 00/507 00 Mobil Super 3000 Formula V 5W30 - I bought it through Aeromotors.ee / 5L can for €39
  • OIL CAP WITH WASHER / SWAG
  • OIL CAP>valve cover / OE
  • OIL FILTER / MAHLE
  • QUICK CLEANER
Coolant resistance -49 degrees.
Tire tread 8-10mm.
Vehicle body visually in good condition.
Timing belt visually dry and tight.
Exterior lighting in good condition.
We lubricated the rear bushings of the front swingarms, which were making noise
The brake system is in working order, there are rustling sounds on the discs.
The digital maintenance book is complete.
The last oil change was a year ago, i.e. 07.03.24 and LS: 125,319 km
So 12,276 km in a year.
02.04.2025 - I received new summer tires Falken Ziex ZE310 Ecorun, 235/45R18 98 W XL FSL - Total 419 €
17.04.2025 - New tires went on the rims today. Mileage currently: 138 970 km
20.04.2025 - The cabin air filter was replaced. Replaced as usual 5Q0819669 - MANN-FILTER FP 26 009
25.06.2025 - Regular car inspection. Next time is in 2027
21.08.2025 - Replacing the spare key battery. Both were dead. Replaced with CR2032
  • 6 months later...
18.02 had regular maintenance - oil change.
LS: 150 290 km
Engine oil: VW504 00/507 00 Mobil Super 3000 Formula V 5W30 / 5L can for 33.73 EUR
OIL CAP WITH WASHER /FEBI BILSTEIN
OIL CAP>VALVE COVER /TOPRAN
OIL FILTER /MAHLE
BRAKE OIL CHANGE
PID.FLUID ESP 1L TRW
Lubrication of rear bushings of primary swingarms
04.03.26 - had the following work done today:
LS: 150 904 km
Replacement of timing belt kit.
Replacement of water pump.
Replacement of accessory belt.
Replacement of crankshaft first seal.
Bleeding cooling system with ODIS.
Spare parts:
530 0650 30 / INA Water pump + timing belt kit
6PK1033 / CONTINENTAL CTAM V-ribbed belt
20037032B / CORTECO Shaft seal, crankshaft
Coolant Polar Premium Long-Life G12evo -37°C 5L
LS: 151596 km
Škoda Superb L&K 2018 - The driver's door no longer locked. A new lock was ordered, Topran 623629 - Price €39 and replacement €90. Now everything is OK! )
