Radio swap information dance to amundsen
26 minutes ago, UrbanPanzer said:
no, from what I can read there is an update via TPi for vw cars, but not relevant to SKoda so people are being told..... (which we know they are the same)...
So you WILL need to buy either a replacement CAN gateway (seperate module) OR as I strongly suspect a replacement BCM with a later revision.
Some reading...........This is for the RNS510, but the same applies for RNS 315
http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting
Replacement can like one of these
I "think" that will work, but I cannot be 100% so do not want to advise you spend money without being sure.
The link you posted is from china, so no real "clear" explanation........
this one however is from the UK (I know it's still a chinese product) but you could message the seller to confirm, he does state in description "fit a later unit without replacing the BCM" which is what your doing, worth a message "imo"
https://www.ebay.co.uk/itm/133700430604?hash=item1f212aab0c:g:IBsAAOSw1clgyNEu
Thanks 👌
Any idea what to search for regarding a bcm for let's say a 2013 fabia
  • Sponsor
I think your wiring loom will be very incompatible with such an item.
