What the smallest size wheels that fit on 1.4 VRS
Quote
Hi Guys
Pretty much as the title says, my VRS is currently on 17s (original) and just wondered what would fit for winter tyres and still clear clippers etc. Better still is there a option of just get a set of original VW, audi , Skoda Seat whatever and stick winter tyres on them.
1 hour ago, instantclassic said:
Hi Guys
Isn't the 1.4 VRS a Fabia MK2? You've posted in the Fabia MK3 section.
The smallest you might want to go on a Mk2 Fabia vRS will likely be 15" and that is the size the Skoda Spare wheel is.
The standard 17" Gigaro alloys are fitted with 205/40 R 17 tyres.
Lots of threads over the years in the Fabia Mk2 section over tyre / wheel sizes.
Just 1 of them.
http://briskoda.net/forums/topic/454871-fabia-vrs-mk2-on-16-wheels
More in this thread.
http://briskoda.net/forums/topic/503390-anyone-fitted-r15-wheels-to-mk2-fabia-vrs
Edited by roottoot
195/55R15 would be a good winter tyre size for the Fabia MK2 VRS if you don't use snow chains.
Suitable rim sizes include 6Jx15 ET43 (standard Fabia MK2 rim size), 6Jx15 ET38, 6Jx15 ET35, 6.5Jx15 ET34. Perhaps even 5.5Jx15 ET40 or 5.5Jx15 ET34 if you like narrow 5.5J rims with the 195/55R15 tyre size. It's more common to fit 195/55 to wider 6J or 6.5J rims.
The 195/55R15 tyre size will better fill the wheelarches when used with ET38, ET35, and ET34 offsets compared to the rather recessed standard ET43 offset.
As you can see in the chart below, 195/55 can be fitted to a rim between 5.5J and 7J with 6J highlighted in bold as that's a good starting point if you're not sure what rim width you want. However, fitting a 195/55 tyre to a 6.5J rim will give slightly sharper steering at the expense of a slight reduction in ride comfort compared to fitting the 195/55 tyre to a 6J rim. For example, the Renault Zoe electric car fits its 195/55 tyre size to a 6.5J rim.
ETRTO approved rim widths
195/55 5.5-6.0-7.0
Dunlop Winter Sport 5 195/55R15 85H
https://www.camskill.co.uk/m95b0s624p130004/Dunlop_Tyres_Winter_Snow_Car_Dunlop_WinterSport_5_Dunlop_Winter_Sport_5_-_195_55_R15_85H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_1_Noise%3A_69dB
6.5Jx15 ET34 5/100 57.1 steel rims 8X0601027A (from Audi A1)
(1) 8X0 601 027 A steel rim
D >> - 10.12.2012
6,5JX15H2 ET34
5/100
black
4 PR-CR7
6.5Jx15 ET34 5/100 57.1 steel rims 8X0601027E (from Audi A1)
(1) 8X0 601 027 E steel rim
D - 10.12.2012>>
6,5JX15H2 ET34
5/100
black
4 PR-CR7
https://audi.7zap.com/en/rdw/audi+a1/a1/2011-708/6/601-601050/#1
6Jx15 ET35 5/100 57.1 steel rims 2Q0601027T (from Skoda Scala)
1 2Q0601027T Steel rim 6JX15 ET35 1 PR-C0H
  2Q0601027T 03C rally black
https://www.lllparts.co.uk/catalogs/skoda/CZ/SCA/584/6/601/601010
Edited by Carlston
@Carlston  Sometime go drive a Mk2 vRS on 195/55 R 15 tyres without changing the Steering Assist setting, (reducing it)  then tell us about the sharper steering or actually the crap steering and the flashing TC light as well unless they are nice grippy tyres on a grippy road surface.
Good.   205 tyres are fine as summer or winter tyres on 17" or just 16", and 215's are fine. 195 on 17,16 or 15 is just not necessary.
This is a vRS / DSG i mean with 180 ps.  Not generally Mk2 Fabias.  Lots of days and miles driven in the UK October to April  are lovely dry and warm days.
http://briskoda.net/forums/topic/294303-vcds-steering=assist-polo-gti-setting
Edited by roottoot
I ran 195/50 16s last winter and it was comical at times. Wheelspin in third on my 140hp tdi
Was great when it was icy and the council didn't salt the roads, but under those conditions everyone else is driving that slow, having winter tyres didn't make a bit of difference.
Nice to have them but this year I'll not bother swapping unless it gets very bad.
In slippery winter conditions while driving a lightweight 180PS FWD car you won't always be able to plant your right foot whatever tyres you fit.
What spare tyre size will fit in the spare wheel well of a Fabia MK2? I'm guessing 185/55R15 fitted to a 6Jx15 ET43 will fit, but anything wider?
Actual width of tyre when inflated (measured from sidewall to sidewall)
185/55R15 fitted to 6J rim 194mm
195/55R15 fitted to 5.5J rim about 195mm
As you can see in the above chart, a 195/55R15 tyre fitted to a 5.5J rim is about the same width as a 185/55R15 tyre fitted to a 6J rim.
This means that if a 185/55R15 tyre fitted to a 6J rim fits in the spare wheel well, then a 195/55R15 tyre fitted to a 5.5J rim will also fit in the spare wheel well.
PROXES CF2
Proxes CF2 has been created to take advantage of the latest materials, structures and tread pattern design in order to guarantee a high level of safety, durability, savings, and comfort.
  Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width Approved Rim Width Range (inch)
zoom-icon.png 185/55 R15 82H 7.8 585 194mm 5.0-6-6.5
https://www.toyo.co.uk/tirefinder/index/width/185/aspect/55/rim/15
Edited by Carlston
  • Haha 1
Winter is not slippery that much for long in much of the UK though.
There are all the lovely days and nights.
@Carlston  where is it you live and drive and do you still have a Fabia Mk1 Estate?
A Mk2 Fabia vRS comes with a 195/55 R 15 spare tyre in the UK.
A 215/40 R 17 or a 205/45 R 17 fits in the spare tyre well just fine.
Edited by roottoot
It sounds like you are describing stretching the same size tyre on a wider rim, which would probably make it feel "sharper", but I personally wouldn't have stretched tyres on a set of rims especially winters.
Why? Having a bit of extra tyre gives some rim protection and a bit more comfort. Winter tends to create a lot of potholes, and a bit of extra tyre is very helpful in that case also.
I know for a fact that a standard 17" Monte wheel with 215/40 tyres, and a Standard Mk1 vRS 16" wheel with 195/50 tyres will fit into the spare wheel well of a Mk2.
