Felicia head gasket nightmare
51 minutes ago, Papez said:
that radiator hose is pretty cramped there... I always wondered, why they just didn't use 1.6 rad with outlet on the left side?
Because this is how companies work.
They had the 1.3 rad.
They found its cheaper to mould that wierd ass looking hose rather than to add the bigger radiator or change the outlet position.
Plus the oe hose did fit a bit better than the aftermarket skv one
  • Replies 101
  • Views 10.7k
  • Please note - I am not a mechanic or expert in anything.   Let the 'fun' begin, sooner you than me but I am sure you will enjoy it (for the most part).  Be interesting to see which new parts
  • For sure that is totally for sure for sure.
  • What's the difference between neighbouring inserts? IIRC, there was a limit, too and it is more critical than absolute value. Edges of adjacent liners should be perfectly in level.
hose and the metal pipe - incidentally in the exact shape that would be needed to connect hose to the 1.6 rad. And they also had to make new radiator anyway to fit 1.6 fan :D It just seems easier to figure out 1.6 rad connection.
Btw, what brand is the new rad? Some "alternatives" might have lower fin density, which could be problematic on a car with AC.
Edited by Papez
That's what I've thought seeing the 1.3 radiator change. Quality of the radiator is very critical on 1.3 size.
Mahle and thermoswitch also!
You think your boy here would settle for quality components?
Ofc not!
Mahle rad!
Head is on valves adjusted.
Although I lubed up the bolts some of them felt marginal so I didn't get the full 180deg more like 170ish.
But I guess that is much better than snapping one.
20nm (since my torque wrench is torsion type it may have been around 25 but skoda gives 20+-3)
90deg
90deg
Edited by Thefeliciahacker
90deg
90deg
/cdn-cgi/mirage/b2a6ebb5516a62a813ba256bbceb36dd8e83d541906d5a304225e76358d80b2b/1280/https://www.briskoda.net/forums/uploads/monthly_2023_01/IMG_20230107_132456.thumb.jpg.ce9c4c0217a6ee1790999e846ca9f48b.jpg
Did you doublecheck the position? It looks like the oil channel hole is on the oposite side..
Haha my friend you are VERY attentive, that photo was a set up, to see if someone would catch it!!!
Here is the real deal!
Ofc, everything was done to as close as I could by the book
Was the photo of a Pierburg carburettor followed by one of (I think) a fuel injector a set up as well?
The tb is made by Pierburg!
The photo of the injectors is just to show they have been cleaned and their o-rings changed to top quality viton ones!
Mine too (as is from the factory) so i added a plastic part to avoid the friction on the oil filter.
The @Thefeliciahacker hose looks much better.
Just bought a set of head bolts!
Last one on Autodoc.
Mislabeled so it didnt appear that it fit my car!
I would have ordered it sooner so not to pay the 13 euros more.
God damn it Autodoc
Will see how long this HG will hold.
It is a PTFE coated payen so simply the best on the market!
Anyhow, will have a detailed breakdown of all the parts and the cost involved.
But I dont think it is more than 500euros
This knob appears very stiff when turning does anyone know how to free it up!
ONLY 35 for new manifold intake and 28 euro for new thermostat?
You can pull it out and use some silicone spray.
Do I see the cables behind it?
used
yes VEMO very high quality with circlip and not the one with prongs!
Or GT85 as it's more versatile for other uses on car and home. - https://gt85.co.uk/gt85-original/
Edited by nta16
ETA: Please note - I am not a mechanic or expert in anything.
where should I use it?
Some photos, lets hope I can make it work properly!!
Startup video will be viewable when its done uploading.
https://youtu.be/jzdHDQAGHhE
Where you would use the silicone spray and instead of WD-40 - sorry I've no idea what mechanism is used behind the heater control knob but you can spray GT85 to lubricate plastic against plastic or on cables (for electrics), etc..  Obviously you must first find out what is causing the knob to be difficult to operate otherwise just lubricating things may cause something to slip, jam or break.
Do you not have a parts catalogue diagram and/or list of heater / heater control parts to give you some idea?
Edited by nta16
I find this photo.
I don't agree with the plastic tie-wraps and the fabric tape close to the manifold.
You can use metal tie-wraps of aluminium high temperature adhesive tape.
In the past i had problem with odour because a plastic part which was around the cable of Lambda was getting overheated and every day i had a bad smell inside the cabin.
https://imgur.com/t0X2FmX
PS: the slippers on both of you was characteristic. 😉
That's the intake manifold
Good one! Maybe you could describe the photo as example how Not to do it :D
The cables should be acessible if you remove the black portion of the dashboard.
Of course is but in the summer period here in GR gets hot, it gets too much temperature from the exhaust manifold especially in long distance trips.
https://ican.gr/product/wd-40-gt85-multi-purpose-lubricant-with-ptfe-400ml-τεμάχιο/
WD-40 GT85
Those with PTFE were we call them Teflon spary, an example:
https://www.skroutz.gr/s/20885544/Wd-40-Specialist-Anti-Friction-Dry-PTFE-Lubricant-Σπρέι-Τεφλόν-400ml.html
some more:
https://www.skroutz.gr/search?keyphrase=σπρευ+τεφλον
