Thoughts on timing belt changes
Hello. My 12 plate had timing belt changed Nov 2017.
I believe the duration is 5 years, but see other forums mention timing belts should be a lifetime part(usually talking about Europe) so what are people's thoughts? Would they change at 5 years(so end of this year) or leave longer?
Also I think the battery is original but doesn't seem to cause any issues so would there be any reason to change it?
Best post up your engine code to confirm if yours is indeed a lifetime belt.  VAG will be covering themselves by changing their tune to 5yrs, that being said I wouldn't personally trust a 'lifetime' belt as the term itself is ambiguous.
If your battery works, and you are not getting any symptoms, you can carry on I would say.  For peace of mind you can take it to be tested and get a basic health report done.
  • Like 2
Which engine, and what's the use case like? For example, the 1.8t and 1.9D engines have water pumps lived at about 50_000 to 80_000 miles driven by the timing belt, so it may well be a good idea to change timing belt, tensioner and water pump every 5 years simply because half the cost of doing so is labour rather than parts.
Is the engine code the vin number?
It's a 2012 1.6 SE TDI cr if that helps?
Would the replacement belt in 2017 paly a part on if it's a lifetime or not?  Or is it to do with the way the engine works?
I think will change later in year early next year for piece of mind but if it turns out it is lifetime then I guess I get more time out of it..
On your vehicle document, V5 there will be engine number.
BMN12345
CAVE12345 for example
@t3rm3y
Cross your fingers, buy the clothes pegs and lucky heather.    Doubt very much it is a 20% failure rate, not even among taxis.
http://briskoda.net/forums/topic/502505-engine-failure
http://briskoda.net/forums/topic/502054-i-am-the-1-in-5
If Skoda / VW did lifetime they could give a Warranty in the UK of the production life of vehicles, so 7 or 8 years.
You might get that in Australia.
Not on a Cambelt though.
The only Life time thing i ever hear from Skoda Main Dealership employees or Customer Service is the DQ200's sealed for life.
Which they are not actually, it is just there is no schedule, guidelines or recommendations for changing the oil.
Edited by toot
1 hour ago, varooom said:
Fantastic , so I changed 2017, don't do loads of miles then 2 years of covid so well within its life 😁
