Karoq cam belt change - start saving now !
You can buy a longer warranty if the car is under 100,000 miles.
No idea what your DSG is unless you say what your Karoq is, FWD or AWD.
  • Replies 315
  • Views 88k
  • As far as I can see (and in my own mind) it is not resolved at all.  This will never ever be resolved until someone (consumer rights group / government) embarrass VAG UK / Skoda UK enough to make them
  • Why do you have to be so objectionable!   I have always found Toot to be  most helpful on this Forum and would sooner take advice from him than someone like you . It is obvious Toot knows hi
  • Routemaster1461
    Routemaster1461
    It is the consequence of failure that is the issue. Generally a failed wheel bearing will cause a little noise and possibly vibration and is easily fixed, but a failed cambelt is pretty likely to be c
Karoq petrol 1.5 TSI FwD    2018 year
A DQ200, no servicing.
Thanks toot, appreciated
I have the same but I’m still none the wiser from the table which gearbox I have, except it’s 7 speed.
Edited by DBSurrey
You have a 7 speed twin dry clutch DSG, of which there is only one type, Skoda produce about 2,500 a day. They are have been used in over 50 VW Group applications, different software, so it is a DQ200.
Not used with a car with Haldex / AWD.
Used with 1.0,1.2,1.4,1.5 & 1.8 TSI, or 1.2,1,4 or 1.6 TDI,s with 150 ps / 250 nM or less front wheel Skoda's.  (Kodiaq an exception.)
Electrified Skoda models, Mild hybrid are a bit different , DQ200-e and a 1.5 TSI PHEV gets a DQ400-e.
Edited by toot
Many thanks.  So no service interval then.  I assume that means no filter or oil to change.  Is there an oil level indicator or dipstick on the gearbox do you know ?
The Dealership staff & customer services will tell you sealed for life.
They are not 'Sealed for life'.  but there is no Servicing guidelines, recommendations or schedule.
 Nothing to be done unless there is a fault. No oil changes at 40,000 or 80,000 miles.   (The wet clutch DSGs have the same oil in the box and MCU, the DQ200 has 2 oils.)
http://briskoda.net/forums/topic/510641-yeti-2016-automatic-geabox-oil-change
Many thanks, once again.
We fitted a new genuine DQ200 Mechatronic in a Leon last week, bloody thing insisted on the immobiliser being recoded with both keys so the customer had to bring in the second key, I mean why? We have done dozens of them and have never needed to do that.
@CrasherI know of one about 7 years back on a Mk2 Fabia vRS that the new MCU came in from Germany and the same thing and more and they needed to get sent a new ECU.
Because VAG urrrggghh, how weird that it needed key for that, must be some additional security malarky.
We have had similar stupid things happen with other devices such as the BCM on a Passat type 36, the usual screen wash output failure. I plugged it in, started ODIS in GFF for the module coding, SVM and “transport” unlock and the entire car went ballistic, changed the coding on nearly every module, reconfigured the ABS ECU for left hand drive and locked it… I mean, WTF!
Edited by Crasher
OT,
My Corsa Electric was in for days and was shutting down during a Recall Action on it.
That is what happens with a Dealership without the Bandwidth in the building to do & complete the updates and they get to 98% or so and then that is it,
try try and try again.   Technically known at Robert the Bruce's spider procedure. .
Less OT.
Remanufactured.
A DQ381
Edited by toot
I now realise how far auto electronics have come on since my first cars. I haven't a clue what these abbreviations mean!😂
You're not alone!
BCM = Body Control Module
ODIS = Offboard Diagnostic Information System (Dealer diagnostic tool)
GFF = Guided Fault Finding (part of ODIS)
SVM = Software Version Management
We fitted a brand new genuine steering gear to a 2017 SQ5 this morning, started the engine and ping, ABS light on... WTF? Went into the ABS, coding incorrect, another WTF! Thankfully I had a prescan so I could code it back quickly, it had altered the coding for a car with direct TPMS instead of indirect, I mean WHY?
I looked at the Skoda UK servicing website today https://www.skoda.co.uk/owners/servicing-maintenance-fixed-price
and note that the cambelt option at year five says 'recommended' but then gets a X against it at year ten. That to me indicates that the change at year five is not a requirement - only at year ten.
Cambelts can fail, but I suspect that nowadays the percentage that do fail, given the volumes of cars manufactured every year, is very low and even then are probably caused by external influence (oil or other contamination) rather than manufacturing faults. Using the word 'recommended' helps Skoda 1) in batting back claims for replacement engines if the cambelt fails and the change wasn't done and 2) gives work for the dealerships. If Skoda just said 'recommended but the cambelts are designed with a 100k mile / 10 year life', then they'd lose these two benefits.
What do you expect from a company that can't even publish the recommended grade of engine oil in the owner's manual ?
On 25/01/2023 at 20:24, varooom said:
I couldn’t see how to remove the plastic cover to access this part of the engine.  Is there another way for me to know whether my car is affected by this issue? It’s a 19-plate, 2WD, 1.5 litre petrol engine, TSI, DSG automatic gearbox, in SE-L trim, registered in the UK in June 2019
Engine code off V5
or VIN sent via PM so I can look
I might then be able to tell what it has, but need a moment as doing other things.
@Mark-Surrey There is no 'issue' other than one with the UK Importers & authorised repairers / Main Dealeships.
You have a Euro 6 1.5 TSI ACT that Skoda UK / VW UK recommends having the Cam Belt replaced at 5 years.
You chose to ignore or not and if you are doing an inspection sooner, or at 5 years or anytime after that then that is that.
33 minutes ago, varooom said:
Engine code off V5
My V5C (log book) document shows the “Engine Number” as 610885. Is this the “Engine Code” you referred to?
It's the letters before that, DACA / DADA / DPCA for example
Thanks for the clarification. I’m thinking of changing our Karoq to an EV within the next couple of years. I might end up switching it before it reaches 5 years old, to avoid the whole discussion of whether to get this cam belt changed at all.
