TMC traffic events no longer being received...firmware update required?
For the SD card it's not coding but copying modified files. You have to use old maps which have designation to do it. Here Maps allowed you to do it. Once TomTom did the cartography for the mib2 standard they left out the flexibility to use Inrix. Here Maps had it in. Mib2 height, it's coding so you can use the latest maps.
If you are good with file copy you can do it yourself with the mib2 standard. I run with two cards in the car with the mib2 standard and swap as it takes my fancy between the latest maps, no traffic reports and the old maps with traffic reports. Oid maps have old speed limits in them naturally and roundabout with extra exits now are short of some.
Think pcbbc is adding some... notification came up.
  • Replies 937
  • Views 236k
  • steveandchez
    steveandchez
    I’m just letting any VW owners that may be lurking here know that I successfully reactivated the TMC on my mib 2 high using 32782 in the 5F module using OBD11 pro.
  • if YOU had contracted the third party, then yes, BUT it was Audi who contracted a third party to provide the service to YOU. Therefore it IS to do with them.
  • I think the vehicle age thing is a red herring. The dealer is spoke to checked his (newer) Golf which had the same problem.  He had checked their “hub” for any information and nothing was forthcoming
2 minutes ago, pcbbc said:
I’m in Orpington SE London. Or one day a week at the office in Horsham. I’m assuming you have MIB2 Columbus system and so just require the TMC coding via VCDS.
Well he's been asking about mib2 standard unless he has a mib2 high as well.
Had a thought may be he's got a mib1 trying to fit mib2 standard files onto a mib1 card... in that case coding for TMC would work but not the mib2 standard maps...
Need a picture of the info screen to resolve I reckon.
Sorry, been very unwell, will start again once feeling better. Fabia 2019 not Columbus unit, Admunson unit from new and not touched.
FC
Effected the UK where the TMC provider that VAG used stopped broadcasting traffic reports. Inrix in the UK continues. Columbus model can be coded to swap the channels to pickup Inrix. Admunson mib2 the guys here worked out a fix for that but you have to use old Maps, Here Maps, they had the flexibility to do this via updating a sequence of modules... overwriting the map file.
The solution is on thid thread. I have reproduced on the SeatCupra board in one place.
TMC UK Solution
Traffic Master discontinued their UK RDS broadcasts of traffic information which VAG cars used in April 2023 for TMC, solution exists by shifting reception to the alternative UK broadcaster of traffic management data, Inrix.
Click for the Mib2 High Fix
Click for Mib2 Standard Fix
For mib1 standard or high follow the Mib2 high fix. Just needs VCDS / Obdeleven code change. Mib2 standard doesn't need coding. See the relevant links.
Mib2 high is a Columbus
Mib2 Standard is an Admunson in Skoda terms.
Full credit to those involved. All info is on the Skoda thread but mashed up with chit chat and getting there. Vag aren't going to fix this issue. It was clear from early on.
Edited by Tell
Hi, I transferred to the INRIX signal after Trafficmaster ceased broadcasting thanks to some great help off this thread, however it has now stopped working. Has anyone else experienced any issues recently? Thanks.
I would agree its currently not being broadcast. TMC crossed out. Whether its temporary or permanent pass. A quick Google on the subject nothing sprung out.
Hopefully just a glitch, but still nothing again yesterday.
I’ve got a longer drive later on so will keep an eye on it.
Might be they havent renewed their license. AI Googles come up with imagined AI answers conflating what happened in 2023 Trafficmaster with Inrix now. In the past when Trafficmaster temporary disappeared it reappeared a few days later then went for good a year later.
Probably somebody knows something.... waiting for it to be written with a reference.
Is there a solution for MIB3 cars at all?
Nope as far as I know. You have to subscribe to connect services to get it over the. Not free.
https://m.youtube.com/watch?v=A-Bw6nEdPqg&t=4s&pp=2AEEkAIB
Use apple car play or android auto and use your phone?
Then a map app
Then a map app
One solution or @pcbbc comment 😉
https://www.ttforum.co.uk/threads/fixed-rds-tmc-no-longer-working-in-uk.2032197/?nested_view=1
I just use the built in and if its a long journey check using Google Maps then if their is a road jam and everybody is turning off... just follow them till you are back on the route 😂. It works.
TMC traffic reports via Inrix were similar to the old motorway service boards. Gives who is doing the work, gas pipes etc. Narrow lanes etc. Actually more on Inrix than Trafficmaster. Inrix being the Highway Agency system so they knew what was going on and Inrix analysis.
Never any traffic round here. Only driving in England where hold ups occur. An English thing 😉.
If it is closed down it was going to happen one day as people move to connected cars and use the built in maps and traffic reports or Luddites that stick with what they know, Car Play and Android Auto 🤣.
Vag use their own system now supported by Here Maps but data trading with Inrix one can assume.
Was out and about all day yesterday and still nothing.
It’s been a good few days now so a growing possibility INRIX has gone the same way as Trafficmaster.
Will update if it does happen to come back on at some point though.
Had another check this afternoon.... nothing. So yes I agree... however we did have the good times for an additional three more years.
It took me a while, but I managed to find a contact at INRIX.
Sadly confirms what we suspected.
i've got same here. Was working with old maps and INRIX, but no longer :-(
Yes they pulled the plug for good but we did get three more extra years by swapping over from Traffic Master to Inrix. It was useful like yesterday long queues at road works in a rural area. Inrix would have told you and marked up the area.
My advice would be to purchase an external SAT Nav like a TomTom unit, for example, or if you have a system with Apple CarPlay or Android Auto built-in, to use that and use Google Maps on your phone. Both of these approaches will also give live traffic data, which I think is provided courtesy of mobile phone tracking and system can see where the mobile phones that were moving before have just suddenly all slowed right or become stationary.
The only real problem with these options is that if you have that little dot matrix screen on your instrument cluster giving you turn-by-turn information on the distance to the junction, etc., that functionality is not present.
One solution or grin and bear it. Generally I checked the route if its long distance before setting off. TMC was handy in that it gave you similar information as the boards they use to have up in motorway service stations. In urban areas when you hit a jam you just follow the people ahead who are all taking the same google maps merry go round then filter back on when required. Works for me.
Connected Vag cars all come with traffic data built in assembled by Here Maps. Keep your contract going for that and map updates. What I'll be doing when I get a new car, till then check for traffic before starting off and at worst tag onto the Google Maps car conga at a diversion. Alternatively on these connected cars or mib2s / 3s use Android Auto or Car Play. Android Automotive being deployed in the latest Vag cars use Here Maps, have the traffic reports if you take the contract out or plug in your phone if that takes your fancy. That covers all bases except external satnavs that always fell down off the window for me. I like them built in with no messing, trailing wires or over heating phones.
Does anyone know if it's possible to switch mib2 /mib2.5 high to use Here TMC in UK. If I good remember ford sync 3 used Here through TMC and never noticed issues.
Edited by Mrk26
There were only two TMC providers in the UK. Both have pulled out now. The VAG / Here Maps traffic offering is only available through connected services.
Thanks for confirmation.
