2019 Sportline - Driver's side rear door lock not locking electronically (key fob or console button)
Hi All,
Got a bit of an odd one regarding my rear driver's side door of my 2019 Sportline Plus, that I'm hopeful you highly knowlegable people might be able to help with.
Sympotons of issue:
  • Door does not electronically lock, either via the key remote or with the button just aft of the gearstick, the car also won't lock itself once in motion (it tries to do it, but fails, button does not illuminate).
  • This  model has the electronic child lock, this works both sides of the vehicle with no issue (i.e. you can open the door from outside the car, but not inside, and buttons illuminate on the drivers door, so all good there).
  • The door can be manually locked by removing the little rubber grommet on the door frame and turning the little slot a quarter of a turn, so that to me says no mechanical issue.
  • Door unlocks fine with the remote/KESSY when entering the vehicle.
What I've tried:
  • Manually locking the door each time as an interim measure.
  • Removed the door trim and unplugged the door lock (essentially making it dead), this then enabled the car to automatically lock the vehicle after take off and the lock button inside the car was then working as it should. The rear drivers door could still be opened from inside the vehicle by pulling on the cable (I didn't bother to put the door card back on).
VCDS Scan:
I've treated myself to VCDS and it's throwing up a 3 errors regarding the rear door lock (AutoSCAN below for full details) which are all electric, but not sure if it will be an issue within the lock or somewhere else?
196650 - Motors for Central Locking
          B122B 12 [008] - Short to Plus
196651 - Motors for Central Locking
          B122B 11 [009] - Short to Ground
196665 - Switch for Central Locking
          B122D 29 [009] - Signal Implausible
I'm not all that keen on spending near 200 quid to find that swapping the lock over isn't going to fix it, but the fact that unplugging it then enabled the car to lock itself after take off, to me suggests that it could be the lock.
Any suggestions of what to try next are greatfully recieved :)
Cheers,
Chattsy
Saturday,29,April,2023,11:26:27:47421
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: TMBKH7NP2K7064762   License Plate:
Mileage: 143477km-89152mi   Repair Order:
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 3C 42 44 4B 52 5F
          6D 75 BB BC
VIN: TMBKH7NP2K7064762   Mileage: 143477km-89152miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
BB-Door Rear Drv -- Status: Malfunction 0010
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 KD    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 4798
   Revision: B4H25---    CVN: CFB81915B866C2ADB866C2AD
   Coding: 01250412036405087000
   Shop #: WSC 33361 790 00172
   ASAM Dataset: EV_ECM20TDI01104L906026KD 005005
   ROD: EV_ECM20TDI01104L906026KD_005_SK48.rod
   VCID: 76B5F58DC84CAE6A257-8022
   VINID: 91D49B6077A009B1C01841C608CA7425C3
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0GC 300 044 F    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2401
   Revision: 00H06V07    CVN: F5C0E629
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061.rod
   VCID: 2B0314F9438EA3828A9-807E
   No subsystems:
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0754
   Revision: 00000000    Serial number: 60729000000480
   Coding: 1E07929C34260B70477E060660C54978492CD0E2600692753861F078C282420B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 7AADE1BDFC54CA0A41F-802E
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0509754786 Dataset Number: V03935280JL 0001
   Coding: 032C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D35C59CB1E4BC2529-8016
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 CS    HW: 3V0 907 044 CS
   Component: AC Automat    H34 4402
   Revision: 20K10000    Serial number: 00000B01290076
   Coding: 1211010400211001100500000010102A
   Shop #: WSC 33361 790 00123
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 074B8849BFA6A7E24E1-8052
   Humidity sensor: exterior:
   Rear air conditioning block 1:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 00001908101453 Dataset Number: V03935287MB 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7DA7EAA1ED7AFD3264D-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x RL 160119  032 0121
   Serial number: 00000001901110301564
   Coding: 164DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052 0107
   Serial number: SAY19M03D21H17M26S31
   Coding: 00084D
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY190431UMY
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0314
   Serial number: 00002856223982850087
1 Fault Found:
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 143477 km
                    Date: 2023.04.29
                    Time: 11:21:34
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Automatic high beam assist: operated
                    Low beam: Not operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    last_wakeup: no cause for fault protection
                    Voltage: 12.7 V
                    Outside temperature: 8.5 °C
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019075 Dataset Number: V03935274DW 0001
   Coding: 0471055851
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 4CC17765E64084BAA33-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Dataset Number: V03935285TJ 0001
   Coding: 3200678251FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3537328195CAE572ECD-8060
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BS    HW: 5Q0 959 655 BS
   Component: AirbagVW21    007 0403
   Serial number: 003FMR558PE  Dataset Number: V03935299FG 0001
   Coding: 98CCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 127DA91DC4E4124AA9F-8046
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 001 603 19
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000358540A3A
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 903 19
   Component: SideSensor_Pf  001 0887
   Serial number: 3580000000062564D93L
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 480 401 503 19
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011A2C0919322DV
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 480 402 003 19
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001B92F282B53474
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 402 003 19
   Component: FrontSensor_D  003 6149
   Serial number: 3550001BD2EE3D36C3E-
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0235
   Revision: FF035035    Serial number: 20190318400087 Dataset Number: V03935265ZH 0001
   Coding: 6414
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BA3E4B9F36EF3025A9-802E
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3V0 920 911 C    HW: 3V0 920 911 C
   Component: KOMBI         312 2700
   Coding: 27A5091A2F80A600018D6B095001000880000000
   Shop #: WSC 73430 031 00172
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 323D099D64A4F24AC9F-8066
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 23031910800230 Dataset Number: V03935286TX 0001
   Coding: 030100045F087300EB0002DA1C0F00010001070000000000000000000000
   GVL: 01563C0008000600405C80008000C80000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013025
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85DDEDB01C96AAED7-803A
   Generator:
   Component: 0-01-13-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 F    HW: 3V0 919 719 F
   Component: E221__MFL-PR6  H03 0170
   Serial number: 000000000C1430190319
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 3081610705
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 19000041714002
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW48.rod
   VCID: 33330C999BBEFB42C29-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006SBI10992
   Coding: 0014000000000500018280808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide.rod
   VCID: 3D272AA1ADFA3D3224D-8068
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Part No SW: 5Q0 907 686 C    HW: 5Q0 907 686 C
   Component: HRE_Master    H12 0081
   Serial number: 0510438439 Dataset Number: V03935251FB 0001
   Coding: 02011203
   ASAM Dataset: EV_HREntryHella 001028
   ROD: EV_HREntryHella_SK48.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0510472674
   Coding: 020112
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000369397050  Dataset Number: V03935292JL 0001
   Coding: 001D8820DE01020000001100
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
   VCID: 48C94B75F238689A87B-801C
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5082
   Dataset Number: V03935289TA 0001
   Coding: 81170000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C2127A5B6E0343A133-8068
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 21031910802380 Dataset Number: V03935283ZM 0001
   Coding: 000000020900066E00003F01000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: Leimo links  H01 0006
   Coding: 000000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: Leimo rechts  H01 0006
   Coding: 000000
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000369103213  Dataset Number: V03935292JN 0001
   Coding: 001D8020DE01020000001100
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
   VCID: 47CB4849FF2667E28E1-8012
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 565 035 021 D    HW: 565 035 021
   Component: MU-H-LND-EU   H55 1382
   Serial number: A853C0KB115741 Dataset Number: V03935300GJ 0001
   Coding: 03840201FF00000041111201008808102F0108C601200500DE
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   VCID: 0F7BA069D7D6FFA2861-805A
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 3V0 919 606 D    HW: 3V0 919 606 D
   Component: ABT_High-2  H52 9130
   Serial number: SKZ6ZHW0812572
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 818 H    HW: -----------
   Component: ECE 2022/2023  --- 0197
   Serial number: --------------------
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1017
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: 32380754100000 Dataset Number: V03935272KG 0001
   Coding: 0D08
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   ROD: EV_DeckLidCONTIAU736_AU37.rod
   VCID: 45D74241C52A75F27CD-8010
Address 75: Telematics (J949)       Labels:| 5QE-035-285.clb
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------    Dataset Number: V03935285TV 0001
   Coding: 03840201EA421A0D3F1C9E000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW32.rod
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q4 959 595 F    HW: 8W0 959 595 F
   Component: TSG HFS       005 0246
   Serial number: 0000368538118  Dataset Number: V03935280UB 0001
   Coding: 001880208001020000001100
   ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 4ACD717DEC349A8A91F-801E
3 Faults Found:
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 103
                    Mileage: 143477 km
                    Date: 2023.04.29
                    Time: 11:21:45
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 143477 km
                    Date: 2023.04.29
                    Time: 11:14:09
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 4
                    Reset counter: 63
                    Mileage: 143477 km
                    Date: 2023.04.29
                    Time: 11:14:10
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      005 0246
   Serial number: 0000368535898  Dataset Number: V03935280UA 0001
   ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
End----------(Elapsed Time: 01:56, VBatt start/end: 14.6V/14.6V)-----------
