OCU Update
2 minutes ago, matism said:
Interesting! When was 332 released and can you provide it?
Yesterday and yes
  • Replies 106
  • Views 28.2k
On 15/08/2024 at 12:32, Rainesh said:
Yesterday and yes
Hi great news I could not find version 332 Mib3 Skoda is it possible to have the link also in pm Thank you
Sent me pm
Quick question, what did the OCU update do exactly? Was just wondering if it got any additional features.
No more functions, simply is an update
So far I didn't notice any additional features.
can the files for the ocu also be used with an octavia nx? i currently have 067
just one further question, how long does the update process take?
Hello
Can be that becous my ocu module is not al latest firmware dont work my skoda app?
In car says that must set a primary user…but i cannot become primary user there says is an error….
My Superb iV (2020) had MIB 0156 so I am planning on updating the OCU and the MIB
If you don't activate the Navigation (SWAP) does this affect the ACC at all - I'm sure it uses the maps to determine road speed limits in some situations (I have already updated the maps to 24/6)
I will get the SWAP done, my car is booked into the dealer, but the earlier they had was 26th Feb
@Rainesh I tried to message you re a link to 332, but it says you aren't accepting messages...
let the dealer update first and do the swap. Afterwards you can update to 332.
I updated to 278, then used ODIS to add the SWAP.
I've now updated to 308 and just about to do 330.
Is 332 thr latest update and where can I find it?
Also how do you check the version and update the VC?
Edited by MARViN2003
Ciao a tutti. Prima di tutto, grazie perché ho imparato molto dalle vostre discussioni. Devo aggiornare il mio MIB 3 dalla versione 306 all'ultima che risulta essere la 330. Capisco che devo passare prima dalla versione 308 ... Ho una OCU versione 0.35 e da quello che ho letto, per aggiornarla devo passare prima alla 088 e poi alla 143. A destra? Devo prima aggiornare l'OCU? Viene sempre fatto con una chiavetta USB? Qualcuno può fornirmi il file della versione 088 perché non riesco a trovarlo da nessuna parte. Grazie
Hello,
I bought a Superb iV MJ21 2 months ago and I am updating my modules step by step.
My MIB3 is already on Version 0330 but I have issues with the my Skoda app regarding opening and closing the Car vie App.
My OCU is a 5WA035284B and is on Version 0035, I guess that's my Problem.
I only found Versions for 5WA035284 without "B", can I use them anyways?
As I am using Version 0035 I need to update to 0088 first, and then to 0143 or 0146 - is there a possibility that maybe @Rainesh could provide me with the files?
thanks
Edited by Kermit80
If someone manages to get their hands on 88 version for the same hardware as the post above (5WA035284B) I would appreciate it. I do not have enough posts to send a message to @Rainesh
Thanks.
You can go directly to 143
Thanks for the quick answer! So from 0035 -> 0143 without any issues along the way?
It wont let me update. It doesnt show proper in the photo but everything is grey and disabled. Any ideas?
You are trying to install the wrong update. You have index B and trying to install non-index firmware
Thanks again for the hint. That was my only guess about what could be wrong. I was not able to find the B version anywhere to download (not even drive2), so I thought it was wrapped around the non-indexed one. Do you know where I can find it?
I will sent you a message. I need your vin.
Can You send me please also a PN? I can't send PM yet, but having the Same Problem.
Thanks from Germany
Edited by Kermit80
Hi @Rainesh,
Just a quick reminder when you have time. I still haven't received your message.
