Skoda Superb 2023 OBDEleven Long Coding
oztaburak
Recommended Posts
I have Skoda superb 2023 (l&k) and Nextgen OBDEleven with ultimate plan. Wanna share all codings I found from browsing and youtube. You can find that which ones are tested and running and which ones are not running. Obviously some of the adaptations have been changed in new OBDEleven software and some configurations are moved under other menus such as BAP2 and GEN(still trying to find them). I'm planning to update the list as much as I can find new and running codings and keep this list up-to-date. Please don't hesitate to share any thoughts and coding.
  - Tested and running
 - Tested and not running ()
Long Coding List
Refuel Quantity
17 - Dashboard
Long Coding
volume to be replenished
Toogle byte mode
Byte 10
Bit 4 set to active
Drive Mode on Dashboard
19 - Can Gateway
Long Coding
Toogle byte mode
Chose Byte 8
Check Bit 4
Show fan intensity in auto mode
08-Air Conditioning
Long Coding
Blower display in auto  operation
Set activated
AM disable
5F information Electrics
Adaptation
Search function_configuration_radio
AM_Disable activated
DRL settings in head unit  (there is no any adaptation item contains 'BAP')
Central electrics
security access 31347
adaptation
BAP order bedienfolge
set active
DRLs OFF when handbrake is on  (there is no any adaptation contains item 'handbremise')
Central electrics
adaptation
Augenlicht handbremise
set active
Alarm Beep Activation
Central unit
Adaptation
Anti_theft device
Search Dwa alarmverzoegerung
Set Driver door contact thatcham
Search dws camper modus
Set active
Search ueberwachung ınnenentriegelungshebel
Set active
Akustischer alarm signalhorn
Set active
Akustische Rueckmeldung global
Set active
Offroad
Adaptation
Search compass
Search Car_function_adaptations_Gen2-menu_display_compass
Set activated
Search Car_function_adaptations_Gen2-menu_display_compass_damp_15_off
Set activated
Search Car_function_adaptations_Gen2-menu_display_compass_0x15
Set activated
Search Car_function_adaptations_Gen2-menu_display_compass_0x15_msg_bus
Select comfort data bus
Traffic Sign Recognition
Mutimedia
Adaptations
Select: Car_function_list_BAP_Gen2
Select: traffic_sign_recognition_0x21
Set activated
Multimedia
Select Adaptions
Car_function_adaptions_gen2
Select: menu_display_road_sign_identification
Set activated
Driver Asistance
Select Long Coding
toggle byte mode
Byte 16
Bit 4 enable
Traffic sign recognition VZE
SET active
Dashboard
select long coding
Byte 5
Bit 2 enable
Traffic sign recognition installed
Set active
Multimedia
Select long coding
Toggle byte mode
Byte 24
Bit 6 untick
Traffic sign display (vza)
Wish List
Coming/Leaving Home light animation (like here-> https://www.youtube.com/watch?v=u0ELI2WJK6Q)
Gear Box KM Check
Green Score Information Screen
Dashboard vRS Theme
Start Button Dimm
Navigation Compass in Dashboard
Lane Assist Setting Memory
Smart Link Restrictions Unlock
Battery Charger Level
Headlight Washer Activation Count
Hill Start Assist Settings
Dynamic Start Assist
XDS Electronic Differential Lock
Interior Light Fading
Video in Motion
Lane Assist
Central lock with IGN
Link to comment
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
