Help required swapping steering wheel to multi fubction one
Please if someone can help me, would be appriciated.
Im wanting to upgrade my fabia monte carlo 2014 1.6 tdi steering wheel to a multi finction.
I can buy tge steering wheel and loom off ebay and i am aware it will need coding after. My question is, do i have to swap the clock spring or squib or clock spring to make this podsible?
What wheel do you have? I have a set of switches and loom from a yeti with 4 spoke wheel and don't think my bcm will support it so may abort.
Is that from an Octavia ?
Edited by UrbanPanzer
Yea its off octavia but its same fixibgs as mine.
That maybe the case, but the Fabia multi function wheel only has switches on the Left side .......the right is blank,
so even "if" it's possible to plug and play (which I doubt) with a factory loom ( which would be specific to the Octavia..........I think the Fabia will be possibly "lacking" some of the connections in the car loom for the right hand switches, so you would need to wire these in manually or not use them.
Thats ok as long as the left side works fine for track skip and volume, im good lol.
The buttons I have were described as below, may be going spare yet.
"Skoda Octavia 2 Superb 1 Mfsw Yeti Multifunction Buttons Steering 5E0919719f"
The loom with it has p/n 5ja 971 584.
Edited by dilligaf
Dilligaf, how mucha and are they fully working?
No Idea if they are working as bought off fleabay, the rolling buttons seem ok which looks to be a normal point of failure, they owe me £45.
I would still like to get them working if I can, just waiting on some advice via the ross-tech forum.
I have just read that some wires are needing added for the MFSW to work, can anyone give me more details on what is needed where? This may be where I've gone wrong, I had assumed it would be plug and play with a bit of coding.
I took mine to garage and they run me 2 new wires to body control module, not sure what pins etc
Just an update, i swapped out the buttons for 5E0919719f off a yeti/superb and walla.....it all works
That bodes well for me then, nice one.
Woohoo! Lin & 12v cable in, a quick play with vcds and all works fine.
I no longer have a spare set of buttons and loom.
Sound, thats both of us sorted then lol
