Front caliper nut rubber covers
Recommended Posts
Whatever the local tyre garage did while I was at work this morning lasted all of 2 miles which begs the question "what did they actually do that made it go away and why didn't it last?" Yes they did the droplink up to (presumably) the correct torque but that's all.
Anyway, for the sake of £17 of their labour (15 minutes) I do feel a bit vindicated now in terms of my own mechanical 'skills'.
Edited by LesCM19
Link to comment
Share on other sites
Regarding fitting a new droplink, why does it say in the Haynes manual to only tighten the bolts with the car on the ground?
Link to comment
I've put the old droplink back on until I can find Nylocs to replace the nuts that came with the new ones that keep coming undone, even with another nut on top. Not normal M8 threads that's for sure.
Link to comment
A comment that I would make is, there is more than one thread size(pitch) available even where you have metric fasteners, or, including metric fasteners, typically a "fine" and a "coarse" thread, and for some metric sizes, more than just 2 sizes. I'd always measure the thread pitch before fitting a new bolt or nut, though typically I only buy new bolts/nuts from a local VW Group dealership, doing that means that you end up with the correct fixing first time. You can buy metric thread gauges as well as taps and die sets that cover all or most fixing sizes/pitches used on these car.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
