Cruise Control issue
Hi! i can't get my cruise control to work. It will not engage when in speed. Nothing happens. I have tried the following to get it to work:
- Checked the stalk in Live Data and it checks out and in getting feedback from OBD11. No clutch engaged or brake.
- Tried putting in the activate code in Engine Module. Did a Throttle Body Alignment in OBD.
- Removed the microchip on the stalk and cleaned it.
- Checked all the fuses.
I have no idea where to continue from here.
Thanks in advance!
I take it the engage switch on the top of the stalk works?
Which car?
Profile says 2013 Yeti, but this the mk2 Fabia subforum.
Yes, I get different outputs on all three switch mode off, middle and on.
37 minutes ago, Breezy_Pete said:
Which car?
Sorry, have not yet updated that. Its a Skoda Fabia 5J 2009 Estate.
- Adding the full scan on OBD11:
Spoiler
VIN: TMBJC65J393096640
    Car: Skoda Fabia
    Year: 2009
    Body type: Estate
    Mileage: 251470 KM
01 Engine
    System description: MARELLI 4HV      G
    Software number: 03C906024B
    Software version: 2491
    Hardware number: 03C906024F
    Hardware version: 000
    Serial number: SKZ7Z0H5210773
    Coding: 0000071
    Trouble codes:
        No trouble codes found
02 Transmission
    Trouble codes:
03 Brakes
    System description: ESP 8.0 front   H06
    Software number: 6R0907379E
    Software version: 0002
    Hardware number: 6R0907379N
    Serial number: 00000000000000
    Coding: 0002362
    Trouble codes:
08 Air Conditioning
    System description: CLIMAtronic SK25
    Software number: 5J0907044A
    Software version: 0608
    Trouble codes:
        01273 - Fresh air blower
            static
09 Central Electrics
    System description: 0000 BN-SG.         2S36
    Software number: 6Q1937049F
    Coding: 25998
    Trouble codes:
15 Airbag
    System description: QA AIRBAG VW61 Q5Q6 0004
    Software number: 1C0909605F
    Coding: 20801
    Trouble codes:
16 Steering Column
    Trouble codes:
17 Dashboard
    System description: KOMBIINSTR.    V2802496
    Software number: 5J0920841B
    Coding: 23113
    Trouble codes:
19 Gateway
    System description: 000G GATEWAY CAN    2S36
    Software number: 6N0909901
    Coding: 00014
    Trouble codes:
25 Immobilizer
    System description: IMMOBILIZER    V2802496
    Coding: 23113
    Trouble codes:
37 Navigation
    Trouble codes:
44 Steering Assistance
    System description: LenkhilfeTRW        V272
    Software number: 6R0423156
    Coding: 10140
    Trouble codes:
46 Comfort System
    System description: 03 Komfortgerát     0001
    Software number: 5J0959433A
    Coding: 00019
    Trouble codes:
55 Headlight Regulation
    Trouble codes:
56 Radio
    System description: Radio
    Software number: 5J0035161A
    Software version: 0013
    Hardware number: 5J0035161A
    Hardware version: 005
    Serial number: SKZAZ4H7536062
    Long coding: 05000400000600
    Trouble codes:
        00856 - Antenna, on radio Open circuit
            static
76 Parking Assistance
    System description: Einparkhilfe
    Software number: 5J0919283
    Software version: V005
    Serial number: 08081081291942
    Coding: 0000030
    Trouble codes:
        01546 - Center left rear park assist sensors Short circuit to B+
            static
        01545 - Left rear park assist sensors Short circuit to B+
            static
        01547 - Center right rear park assist sensors Short circuit to B+
            static
        01548 - Right rear park assist sensors Short circuit to B+
            static
77 Telephone
    Trouble codes:
Edited by milowanman
Data log
Are you looking at the cruise control switch on the left or the windscreen wiper switch on the right. The windscreen wiper has 3 settings for little, big and bigger drops. The cruise control on the left switches on and off - no 3 positions. At the end of the stork you can set the speed and increase and decrease.
Yes tried everything. Moving the stalk in different positions and in giving feedback from it. On, off and cancel. Its just that it will not apply it to the engine. You can see in the images that im getting feedback but it will not apply that to specified speed.
Edit: Also bought a new clutch pedal switch but no difference.
Clutch switch
Do you have any DTC stored in STG 01? Cruise control will not work when fault codes are present. Other than that the brake and clutch pedal will disable the CC.
No DTCs stored in any module all except for the Parking Assistance.
- What im thinking since I bought the car used is that the J500 steering angle sensor have been replaced and should really have been a G85 since I cant access the *16 steering column module.
Can you share the VIN/Chassis number, so I can see what was factory fitted, please? I think G85 was only used on cars with ESP, at the time yours was built.
I believe on cars without G85, the correct module address for PAS is 44, steering assist. Maybe even for cars with G85.
Sure, no problem VIN: TMBJC65J393096640
Sidenote: I do have ESP, and I guess Drive-By-Wire.
That VIN does show a normal rack-mounted steering angle sensor, but wiring info suggests it should have a G85 sensor as well. I don't currently know where that is normally found in the parts catalogue, to check whether you VIN says it should be there or not.
Hmm, So if I would have replaced the slip ring and stalk to another one with G85, wonder if it would work then or if it would be non compatible?
- Noticed another thing when checking the speed on each individual tire there was a difference in speed about 2 km/h on left right tire, thinking if this could interfere somehow?
Ah, you've just led me to where the G85 is, shown as item 2 here, current part number for your VIN is 6Q0 959 654C.
Frightening price new from Skoda: £225 + Tax here in UK.
Are the tyres exactly the same size between sides, and worn approximately the same amount? Going in a straight line?
Ohh, okey. Do you think that if I would change the slip ring I would be able to get access to Module 16 or that the cruise control might work?
- Yes the do seems to be all the same. A bit more pattern on the rear axel but otherwise the seems the same.
- I do guess that when you push the set on CC it would be telling the engine ECU to hold the speed, since the ECU is recognised the input from the CC could there be something in the Eeprom that isnt working or could there be any mechanical fault?
UPDATE: Did replace the whole Stalk including the clock spring. And now it works flawlessly. I don't see the green icon in the cluster board but the cruise control works.
But with that said I got a new problem with I'm getting 00778 Steering angle sensor
no or incorrect basic setting/adaptation error code in Brake Electronics. But when I try to do basic settings G85 I can't seem to meet the functional conditions to preform it. Anyone have an idea on how to fix?
Thanks in advance
Does the car definitely have a G85 sensor?
I forget the identification of the one on the rack, as opposed to column, but that might be all you have.
Sorry, just scrolled up and see that we've discussed this before.
Yes, the problem is that can't perform a basic setting. So the anti skid light is always on.
