280 spark plugs
Hi. I need to change the spark plugs for my 16 plate 280, and would want to go for the NGK ones. Anyone using iridium ones instead of platinum/double platinum?
ILFER7C8EG Ngk ones. My last set did 50k miles with no problems and I’m mapped
great plug
Can I ask why? What symptoms points to failing plugs?
They aren't failing, but it has been 45k since they last been changed, and I think this is the recommended interval to change them.
great plug
Are you sure these are the right ones ? I've put my reg and it shows them as not compatible with my 280
http://opieoils.co.uk
Edited by Rooted
17 minutes ago, Rooted said:
Thanks. Seen that on opie, but was thinking what iridium plugs will fit.
@LeGrumpy   Is there something you have in mind about you benefiting from one type over another?
Is it a standard engine on a standard map running E5, or do you use E10?
It's stock atm with stage 1 in mind soon, and from what I've read standard plugs should be fine, but looking at the price of some of the iridium ones, the difference in price wouldn't be that big.
I always put super unleaded in it, either Momentum 99 or Shell V power, and all of these are E5 if I'm not wrong.
Just put my reg in and they came up. I’m MY19 68 plate
I just fitted a set of the OEM plugs to my 272 as a lot of tuners I contacted say, even at stage 2 say they are more than capable of running the extra power. At this point I’ve seen no indication from my own car that, that is anything but correct.
Denso IKH22 are Iridium
In Denso catalog it is for CJXB engine, but it is the same as CJXA.
Edited by Bingodalton
