MIB3 map update
On 10/03/2025 at 12:07, travs said:
Ok - this should be v330 for RoW. Maybe download software again from here maybe and see if this fixes it (the zip with P33000P in the name)
V330 RoW download
(If a login popup appears, its “guest” for both username and password)
Hi, i have tried updating from your given link. But the version is same so the "start update" is greyed out. Was anable to update, due to version similarities.
Also Checked their files was completely identical.
  • Replies 113
  • Views 37.3k
  • As per topic title - question relates to MIB3 infotainment system which doesn't have SD card slots.
  • It can’t be. You said you had v306 updated to v330 - the version you’ve quoted here is version 324 so while it is RoW it’s not what has been installed. You need to find the v330 that you’ve shown in y
  • Ok - this should be v330 for RoW. Maybe download software again from here maybe and see if this fixes it (the zip with P33000P in the name) V330 RoW download (If a login popup appears, its “guest” f
Update. I visit my nearest skoda workshop they have take all the Hardware data and forwarded to the skoda india team to rectify the issue, because they said they haven't seen issue like this. So they are blank & sent the data to superior team. Once they reply on this, he will call me.
In india, if you get your vehicle coded by unlocking extra features which company have hidden them. They they try to afraid you, by telling that you will not get warranty on this that...if they find out they just drops the car right away. And my car is coded by myself.🫢
On 08/03/2025 at 19:04, YashD111 said:
Hello my self YASH i m from India i owned facelift Kodiaq 2L TSI EA 888 Gen 3
recently i updated my Columbus MIB 3 (has NAV button) system SW from 0306 to 0324 to 0330. It was successful with the red engineering menu.
My old system info is:
Device part number: 3V0035832L
Hardware: H22
Software: 0306
Navigation database: 21.7
Media Codec: f9e14198f7aab72315764a90167cddc388ec950c
PHOTO-
NEW system info is:
Hardware: H22
Software: 0330
VOICE MENU Media Codec: 66ea7928ba6ab39efec3edd00faf125661a56389
PHOTO-
As you can see in the photo the Navigation database version is missing and my NAV didn't work at all it keeps loading on starting navigation... nor working on Digital cockpit. Help!
Also tried to update map (india map 8gb) from Update portal
and followed the MIB3 colombus pdf for usb case but didn't work as well
also contacted the dealer but no luck.
need Help!
I only code things that are not obvious. Stop / start I revert back when it serviced. Mind you I did mess up the maps, being a Seat mib2 high they don't have life long Mapcare like Skodas. Learning curve then. Nobody really knew then.
It appears mib3 firmware is more complex so user modification isn't a good idea... I reckon. Map updates are fine but adjusting the firmware is more problematic. Connect services if available in the country take care of firmware updates and you can always go back to the dealer if it fails. Outside of Europe where connect services don't exist DIY on firmware updates can be problematic.
hi everybody.
mibsolution website update files are faulty (330).I recently updated it 0270,308,330..I applied navigation patch after 330(with vcrn code).I didn't have any problems.If the hidden feature is active in your vehicle before updating, you need to restore it (video motion,radio AM enable..).I will share the new update link and details below.
308 and 330 update file (only RW not EU)
https://www.drive2.ru/l/695736324514133028/
The procedure is as follows:
1) Reinstallation of 332 software
2) Checking the full.bin file (exactly the VCRN has changed) 3) Disabling functions:
— MirrorLink disabling speed threshold in motion (MIB3): 0
— Wi-Fi 2.4 GHz Hotspot (MIB3) [U:5F][$0519]: Disabled
— MIB3: Ethernet configuration channel 4 [U:5F] [$09D3]: Disabled
— Applink: Mirrorlink [MIB3] [U:5F][$0555]: Disabled
— Activate the developer mode in the multimedia system [U:5F][$243F]: Disabled functions (do not forget about the manual, open hood) with GU overload. 4) Patch reinstallation
My map is not up to date. How can I update this Europe map? When I enter with VIN code, Europe does not appear(only turket,india..) Meanwhile from TURKEY!
On 14/03/2025 at 16:39, MustafaYuqsel said:
hi everybody.
yes i now i know that why my navigation database is missing the version no.
its because while updating to 330 i haven't known abt these points, that you have mentioned.
i haven't revert any of those extra hidden features to its original values, i have that i have enabled via obdeleven app
so you Can you explain how did you fix it in more details step by step. Please i m having very rough time with the dealership my car is in the works workshop since 3 weeks now. It would be very helpful, If see me as your younger brother! Uploadingbrother!image.png
hi friend you have enabled via obd eleven
1.AM radio disable? (enable)
2.30 colors of ambient lights
3.comfort seats?
4. the menu of locking? (door locking while engine is running)
check these out and reload 330 Firmware.then reinstall the patch and make sure the vcrn code is correct
3.comfort seats?
Yes i actually done too many changes since my car was 1800km
Some of done by professional and some of did by me.
Recently i heard abt the 330v so i tried to implement it and the Navigation database just disappeared.
This is my OLD system info 👇
This is after the update 👆
So as per you- i have to undo all the changes i have done??
I have note down all the changes i made.
appreciate your reply!
3.comfort seats?
Also you mentioned "correct VCRN" and "reinstall patch" how to do that?
close my highlighted ones.Reinstall update 330.Reapply the patch you created with the vcrn code.
I have disable those features you have pointed out. And also reinstalled 330v but i didn't got that last part reapply patch that i have created with vcrn code. (I didn't do anything like that before🤔).
You need to install a patch to activate navigation.
🤔 hmm patch? how to do it? What process do i have to follow? which files? i m confused now! also, i m not that pro at some points.
Can you explain? or share any thread about the topic of installing patch?
The problem I think is that you updated from 0306 to 0324. While to update to 0324 or 0330 you must first install 0308.
Then, once done you must clean the error 1555/B201A with an OBD interface (Obdeleven, Carscanner, VCDS etc)
OK I see there is a new map for AUSTRALIA and NEW ZEALAND on the Skoda portal today
Defintition OP _146........... Contents dated mid March 2025
INSTALLED THIS MORNING AND NEW MAP DEF IS 25.2
After being stuck on map version 25.1 since January, our MIB3 finally updated itself OTA to 25.5 today. (UK).
Better late than never, eh, Skoda.
Edited by mumpsim
Even for OTA updates with an Infotainment Online subscription in place, the updates are, I believe, only around quarterly rather than monthly. Wait until your Infotainment subscription ends and, unless you had Skoda money, then you have to do the long drawn out update via USB-C drive process and you get two updates a year at best.
USB method isn't bad but if I had mib3 I'd probably pay up for rest of what connect services can offer.
OTA updates for us were monthly throughout last year. Subscription was, and still is, in place. I think there is a difference betrween a full release of Europe-wide maps, twice a year, and more frequent OTA updates covering a lesser area. Hence the trick of forcing an OTA update by entering a destination very far away.
Edited by mumpsim
I could see if you had poor 4g you may have to wait over a month if you never moved your car... 4g is shocking where I live and it's a piggy back low bandwidth service they use. I would get zero success.
Yep, 100% confirmed works for a MIB3 critter, format a USB-C thumb drive as exFAT (if not already exFAT), then using your VIN, download your regions maps from:
https://updateportal.skoda-auto.com/
Open the ZIP and copy the contents of the folder (not the folder itself) to the thumb drive and shove it in one of the two front USB's, I'm in Oz, so the map update was less than 2GB. I pretty much started the car and volia!!!!!! I checked under the Infotainments System > System information and now have an updated Nav DB.
Thank you guys, I think the Skoda employee who wrote the English version of the "How To" guide enjoyed a few too many Becherovka's.
Edited by Putter
If in Europa you can do better than that with @MartiniB files. The thread labelled 25.02 has Europe in it more recent. Its the old trick. Vag websites dont show the most recent files at times. Currently its across all sites more or less you can better what a Vag site is saying. Its like libraries of old where new books come in but are waiting for the plastic film, the stamp page etc. The Vag file server has the file but the web site designer hasn't edited the page yet.
This page for the latest mib3 navigation files that the vin lookup may not have (that has 2025.05 for Europa):
Edited by Tell
link
Unfortunately this year's update has had to be abandoned. Six or seven attempts at downloading the 29GB zip file from the update portal all failed at between 6 and 10GB.
It's a pity successive downloads cannot continue from where the previous one stopped.
I may have another attempt when I have nothing else to do but for now life is too short to worry about this.
You may need a different browser / download manager. If it's a problematic connection using a download manager addon to Firefox can solve it. This is the fix I recommend to one person and it did it.
https://www.briskoda.net/forums/topic/532458-columbus-map-update-2025-2026-mib2-high/page/2/#findComment-5958751
That was on the mib2 high file thread but may help with you. Dodgie servers create problems and connections. Download managers iron things out. The mibsolutions people swear by them since their servers are pretty bad. You'll see the addon talks about multi threading. You just install it. I just leave it sitting there once installed. Didn't configure it. There it's sat for several years.
Different browsers may also work better. That was a GitHub project which works across browser. I reckon it could be built into some now.
Edited by Tell
