ABS, traction and flashing handbrake light?
Basically my car (mk1 Vrs 04)  was parked up for around 4 months and in that time the battery died, when i eventually bought a new battery and started it up it was fine until i started driving and it threw these three lights at me(refer to picture) as well as the 3 warning beeps.
Traction and abs have been turned off as i found out the hard way, but was just wondering if anyone knew why it’s happening .
Also i have a wheel bearing that needs changing if that could be a cause??
(apologies for bad photo as i had to screenshot from a video!)
Edited by cxzx
The wheel bearing failure means the ABS sensor can no longer read the reluctor ring properly, fix the bearing and the light show should go.
Thank you i had a suspicion that that would be the case i’m hopefully fitting it on the 15th ill let you know if it all works🙏🏽
