Restarting when warm after stop start activated
I have a Skoda Superb 2015. Three years ago the changing of the battery fixed a problem whereby, after driving for upwards of 20 minutes, with the stop start activated, the engine would cut out as expected but would take several attempts to restart causing jams, stress etc. Also when stopping the engine during a long drive the same would occur but would eventually start. Starting from cold even sub-zero there was never a problem. Immediately on changing to the new battery (the old one was factory fitted and 13 years old) the problem ceased. The problem has re-appeared over the last two months. The new battery purchased in early 2023 is an efb096 start stop battery from Halfords. They have diagnosed the battery health as fine. Is this a common or known issue?
  • 2 years later...
I have pretty much the same issue, from another post I have the impression changing the battery should solve it. I've bought a 2017 TSI around 18 months ago but no idea of battery age. I'm now slightly concerned your stop/start issue has returned with the battery reported in good condition. I'll keep looking for answers on the forum, so far I understood it was an issue caused by a failing battery (AI search also suggested this), your experience is making me wonder if there's anything else causing issues.
Long crank or reluctant restarts when engine up to temperature can often be due to failing crankshaft or camshaft position sensors - have you had the vehicle scanned for recorded DTCs?
