Trav's 2021 Superb 280 L&K
37 minutes ago, Cairus said:
I assume you have a DCC chassis... have you already retrofitted the slider for adjustment or do you still have the fixed profiles?
@travs you may have found your date to the ball if @Cairus can help you with the DCC slider mod...
  • Replies 70
  • Views 9k
  • Few snaps from work. Such a good-looking car.
  • Engine: Racingline Stage 1 remap (self flashing tool) with TCU flash for the increased torque. Quoted as moving to 400bhp and 520NM (applicable to all engines with Continental turbo and end resul
  • Wagner Tuning intercooler and boost pipes are in. Went to thephirm in Camberley. While I was a bit anxious about the admin as they seemed to be happy with a hell of a lot of work in a day (new discs a
It is DCC but haven’t found anyone who does the DCC Slider Mod. Last guy we thought would be able to do it was ApertureS but he’s drifted away from the forum.
I also only have VCDS and I think you need ODIS or VCPro…
Do you know anyone that can help or have you done it yourself?
Link to mhhauto
Leaving this here.
You need a Tool for Flash Firmware & Dataset
Autoscan from your Car?
Update on this - getting some groaning from the nearside top mount when turning the wheel for manoeuvring; usually when turning right but occasionally when unwinding right lock or turning left.
I wonder if it might be down to the Arteon Top mounts being thicker and therefore being more compressed or putting different pressure on the bearing. If its not by design it might be logically sound but still not quite right...
Brakes replaced. The Mtec/ATE stuff was ok but I definitely felt like I was pressing harder on the pedal when having to haul the speed off when loaded up.
Still just finishing bedding in so haven’t used these in anger yet but they look decent and I’m enjoying the lack of groove/noise. Getting old.
Front - Golf CS reps made by SHW performance.
Rear - VBT CS lookalikes to match.
Pads are Ferodo DS2500 all round
Edited by travs
Not sure if you got this sorted, if not then rotate the spring as I had the Arteon top mounts install and my passenger side was groaning aswell then i took it back to the garage and got the spring rotated abit, all sorted.
I had the guys at my Indy have a little look when they did the service and couldn't see anything obvious. I did speak to them about rotating the spring but they said that the spring goes in the cup and the end of the coil it butted up where it should be in the cup so I didn't think there was any room for adjustment on that unless its rotating the spring away from from its final position. I didn't look at the parts up close before taking them to be fitted and struggling to get a really good in depth video on youtube...
Edited by travs
  • 3 months later...
New (to me) wheels. McLaren 570 super light options. 7.5kg which should translate to less inertia to change wheel speed. And they look ****ing lovely. And will be so easy to clean!
While the front wheel was off I had a go at rotating the spring. It turned easier than I imagined, because the hub was hanging free. Will see what it’s like when manoeuvring. Fingers crossed!
Is it me or there aren't many wheels that suit the Superb! Generally wheels that look great on an Octavia/Golf look ok on the Superb!
They need more kerb rash to suit that car ;)
They look very tidy!
I do prefer an angled look than perpendicular to the car. I also think if they weren’t diamond cut they’d look slightly softer. But they’re a good looking wheel in general, they’re forged, rare as hen’s teeth and exceptionally light. Are they perfect for the car? Maybe not but I absolutely love them for all that they are.
new wheels suit the car nicely 👍
Potential to do list:
Alu subframe and LCAs
Uprated 380mm front brakes and 4pots
Either Stage 2 - likely Trackslag downpipe with 200cell cat and additional silencer in pace of GPF.
Or
This APR Stage 3 standard GPF option
Would love to see if Raclingline do an alternative to this but can't see anything yet.
Make sure u get the right LCA cause Golf, A3, S3 etc LCAs r too short for the Superb.
Edited by JR RS
  • 3 months later...
Partly to have crisp handling, partly to replace 5 year old parts, partly to chase a creak:
Superpro Front and rear droplinks ordered (the creak is front but thought I'd do the rears). Superpro LCAs (standard geometry with poly bushes), H&R front arb. Ordered Superpro but given they're on back order until October, I started hunting around for parts in the country. Whiteline, Superpro and Hardrace are all part of the same group and all on back order, APR/IE and 034 were also rare and the best part of £100 more, but found the H&R one as last in stock at Progressive Parts so happy with that.
Given I'd also been lovetapped in the rear (which showed that the rear bumper had indeed been repaired with putty and resprayed) a replacement bumper has been ordered from a breakers in the same colour (needs a machine polish to tidy but I can do that) and to go with it is a Reiger diffuser on its way too. Will tidy and fit all that together when off the car and then put it on with @OccyVRS when the time comes.
Coolant Vent Union also ordered but, obvs, Racingline version.
Goodies arrived…🤪
Yum… stickers for my tool box
I hope those r not the Golf compatible SuperPro LCAs.....cause they'll b short, width-wise, by a 14.5mm, on the Superb.
Which will affect the camber of ur front wheels.
Good luck with the install for all the stuff.
Edited by JR RS
Recently Browsing 1
