Will it start?
On 13/12/2024 at 21:30, sussamb said:
 Nothing wrong with a bit of French
Exactly why I always got on with members like you, because you get it😂
The “Occy245” idiot who mentioned that I signed off with a greeting…..just doesn’t get it does he🙄😂😂😂
Proof, if ever any was needed, that this forum has gone to dogsh!t
Sussamb, take care of yourself brother.  Maybe one day when all these woke, boring idiots have long gone ill be back, until then, bonjour buddy👋😂
Edited by carefree
  • Replies 90
  • Views 8.4k
  • My 8 year old Moll EFB still testing at 80% - despite stop/start always being used would suggest that this function does not give the battery a 'beating' An idling engine produces emissions - for
  • Battery tech has enabled greater AH and CCA in a given battery size, it might have decreased the self discharge rate on certain chemistrys, longevity is certainly not what it was 10 and 20 years ago e
  • Wow, I wasn't expecting to start such a heated debate! Very mixed opinions and plenty of useful advice, so thanks.   I think come 27th December, I'll see if it will start and if it will, wil
On 13/12/2024 at 12:46, oldstan said:
Bye. We'll miss you.   xx
On 12/12/2024 at 23:55, Occy245 said:
Oh, this guy is still going? Deliberate provocation several days later followed by “this is boring now”…
It’s such a shame this forum doesn’t have a ‘vote to kick’ function.
1 hour ago, Occy245 said:
Should start a treat. Just keep an eye on it over the new few days/weeks depending on how often you’ll drive it, but there’s a decent chance the battery will be fine.
Happy Christmas!
On 13/12/2024 at 13:42, carefree said:
Ok ok here’s what I’ll do, I’ll disable my account so that the certain idiots on here ( you know who you are) can continue with the mind blowingly boring chat that has crept into this forum over the last couple of years.
Was it too difficult or did you change your mind?
I suspect door number one.
Happy Christmas!
Sadly its all become a bit irrelevant at the moment as I've ended up back in hospital with a chest infection before I got a chance to use my car.
When I get home again, I'll connect the charger again and leave it overnight so it should be good to go. The charger is a CTEK MXS 10, which seem to be highly rated, so hope its as good as all the reviews suggest.
Get well first, all the best.
On 05/12/2024 at 13:11, RallySimon said:
I was taken into hospital at the end of August and have only just returned home after major open heart surgery (not much fun I can assure you). I'm not allowed to drive until 27th December, 6 weeks after surgery.
This means my Kamiq Monte Carlo 1.5 TSI has sat unused in the garage for over 3 months now, will be 4 months before I can go out in it again.
I know cars these days with stop/start have heavier duty batteries, and I'm remembering my 5 year old Yeti started without any problems after sitting for 3 months during lockdown a few years back.
I've been out to the garage and the keyfob still unlocked it and the dash lit up with the usual display (needed to get my coat and fleece off the back seat, it was summer when I went into hospital!).
Should it start OK? Reluctant to try it now as that will take juice out of the battery when I can't drive it anywhere to recharge it.
If you have a breakdown subscription AA, or RAC or similar surely a phone call to them would get help to sort your charging problem given your post op condition?
Gentle coaxing would probably the order of the day, possibly a little fib or two!
Glad you're better and the car started ok. Was that after you'd had it hooked up to a charger again?
Edited by sussamb
Glad it's mostly sorted and yourself, take care.😄
Yes, connected it up to the charger when I got home from the hospital on 1st, then disconnected it the next day when I went out. It may not have needed it after a full charge over 24 hours a week ago, but I figured it was best to be sure.
With the type of charger you have it should be safe to leave it connected for extended periods of time. It's designed to support batteries in vehicles that are not used very often. I had one years ago that I had hooked up to a rarely used sports car.
