Flat battery yesterday
It was an over the air update from about 2 weeks ago.
They have not done any updates this week whilst they had the car
  • Replies 56
  • Views 8.2k
  • Sir_Ron_Norris
    Sir_Ron_Norris
    Sorry, Mr McCririck, I can't help, only sympathise with you. I have had four years of having to tolerate this crap. A very weak 12v battery that is likely to let me down at any time. So much so that w
  • They could have fixed your car instead ffs. Excessive drain of 12V is years old problem and there were solutions rolled out like 2 years ago already. After they applied fixes and changed battery on mi
  • No, not only for the systems in the cabin; there are plenty of relays and low-voltage components powered by the 12V battery.    Unfortunately there's no scenario which allows the HV battery t
Does phev use HV battery or 12v battery to start the petrol engine? Im quite sure it doesnt have regular starter motor.
The ICE is started by the electric motor (that can be used as a motor, generator or starter), so it uses the HV battery.
So is the 12V just for the systems in the cabin? Can it be supplemented/charged by the HV battery?
There is no 12V alternator so logically electric motor or plug charges HV battery -> HV battery charges 12V battery. Pls someone correct if im wrong.
Unfortunately there's no scenario which allows the HV battery to directly charge the 12 V battery.
AFAIK the 12 V battery on our cars can be charged while:
- driving in EV-mode;
- driving on ICE;
- charging the HV battery.
I remember seeing such a diagram on some technical documentation posted on this Forum if I remember correctly.
The normal Car Battery is there needed for the door locks, lights, the ECU,s controlling everything.
I'm not sure that's exactly the case. When car is parked but ignition is on, all 12V consumers are drawing power from HV somehow. I mean, switch on music, fans, etc and you see consumption in the range of 0.5-0.9kWh/h on the VC. Does it bypass 12V battery or does it go through the battery, I don't know. But myself I often sit in the car for long time and as long as ignition is on, it drains HV battery and 12V stays charged.
Yep, with ignition on, I don't know how the 12V systems take/drane power from the HV battery - if it goes through the 12V battery or not.
My previous statement was related to the "car parked and turned off" (e.g. overnight) - when most of the reported 12V battery drain occurred.
The car includes a HV to 12V down converter so, in theory, the 12V battery is charged whenever the HV battery is being charged. I say in theory as there have been several owners complaining of the 12V battery going flat, but it appears that a software update to this system supposedly fixes the problem.
Yep, I mentioned that in the enumeration a few posts above...
Battery flat again
2 hours ago, mccririck said:
Battery flat again
Had flat battery Tuesday. Today it gave yellow warning. Low battery. No clue what’s happening as well
Mine goes in for a service tomorrow. I'm sure they'll just charge the battery up and say it's ok...
Could be the alternator?
They don't have an alternator.
I stand correct. It would be the DC-DC converter.
Edited by SkodAlex4RS
I think it's more likely the control software for the charging circuitry is poorly designed.
Having had the car in at the garage last week to be told the 12v battery issue was fixed by an over the air update, they were wrong.
even though I have had the car 14 months I am back to telling  Skoda I am rejecting the car.
Pfff this is the future. OTA updates for battery’s.
It's possible they could improve the charging software like that but clearly it was either a lie or they don't understand the problem properly. It's not good enough really being in the situation where you don't have full confidence in your car's reliability.
  • 4 weeks later...
Car was at the dealer yesterday to look at the 12V battery issue. They say they identified a problem with some modules drawing too much current, and xdid a software update. We shall see if that fixes the problem...
And the battery is flat again...
How old is your battery?
Same age as the car. 1 year and 5 months. 33k miles.
