Brake caliper guide pins
Good evening from The Gambia West Africa I have 2 questions 1) which VW Golf is the 2004 Fabia equivalent to Is it a MK3 of MK4? 2) Does anyone know the thread size of the front brake caliper guide pins as I need to retap the caliper because the threads have been stripped Thankyou
That depends which calipers you have.
FSII calipers (239mm discs) have an M8 thread. 6mm hexagon bit to unscrew bolts.
FSIII calipers (256mm discs) are an M9 thread I believe. 7mm hexagon bit to unscrew pins.
Edited by Breezy_Pete
