Park Assist retrofit: car doesn'r appear on screen
Hi there!
on my 22 FL I retrofitted the park assist buying the whole kit except the control unit (seller for other parts hadn't it available) which I got somewhere else. I also fit the rear camera with dynamic guidance lines. When engaging the reverse or activating the front sensors the car doesn't appear on the screen automatically (as before the retrofit) but it does if I press the top left corner of the screen. Mechanic told me it may depend by the control unit which was initially codififed for an Audi A3 even if the part code is always the same. So I went to Skoda dealer who made work the Park Assist (resetting the control unit) but the car doesn't appear automatically: is it matter of coding or what else?
I'm also going to retrofit as well, in the next weekds, the area view 360 and blind spot mirrors, replacing again the rear camera: can anybody help me with coding?
  • 3 months later...
Since you installed version 5QA (the one intended for your vehicle according to ETKA), has this function been restored?
In my 2023 Kamiq, when I retrofitted the park assist, I went from 5QA919294J to 5QA919294K.
Edited by Vincent_83
I retrofit with K as well but car didn’t appear back yet when putting the Reverse
I have the same as yours, and for me it's work. Maybe I can help you with this issue
Audi Unit...
Wrong Dataset
For coding, maybe you can find a difference. Maybe dataset of your module if you take it from another car
Coding Karoq with Index J and towlbar MJ 25
5QA919294L --> 8471151941
Kamiq Index J without towlbar
5QA919294L --> 8471155841
Sorry 8K
I will Check 12K...
Edited by Cairus
I do have retrofit park assist as well area view 360° and they work fine! I just have to calibrate better the side cams
First you say you have to upgrade it, now you say it's already working? You have a lot of contradictions yourself
And Area View dont have To do something with PLA
Blind spot NEVER worked on my car; area view and park assist do even if I need to calibrate better the side cams for area view
  • 3 months later...
An update: as @Cairus said, once I uploaded the correct data set, the car appeared again when engaging the Reverse gear!
Furthermore now the side cameras aim correctly on the ground, even when I activate/engage with reverse the area view!
Thanks!
Edited by Benja77
Hi. I also want to retrofit front pdc on karoq fl. I bought everything needed except the front grill caps and holders. You know where to find them? You have any part number?
