How to: Travel Assist and Heated Steering Wheel Retrofit
With a lot of information already available on the forum about travel assist retrofit but nothing about heated steering wheel for our mk4 i decided to post my way of retrofiting both of them along with a video of showing how to do it along with the codings
For this retrofit to be able to work on your car you need to have already ACC and Lane Assist
For some modules will need SFD unlocking to be able to do the codings
Parts Requirement
-5E3419093AT heated steering wheel with travel assist button
-Heated Cable adapter for the combination switch
https://www.aliexpress.com/item/1005003791804873.html
-5Q1953507GF COMBINATION SWITCH
For travel assist:
20103 security code
Select Driver Assistance A5
- Select Long coding
- Select KLR
- Set to Coded
- Select Point of intervention
- Set to Early
- Select HC Warn Intensity
- Set to Setting_over_menu
- Select HC variante
- Set to Variante_2
Select Adaptive cruise control 13
- Select Capacitive_steering_wheel
- Set to Installed
- Select Travel Assist
- Set to Activated
Select Gateway 19
- Select Adaptation
- Select Specified installation of sub-bus users
- Select Control module for sterring whell touch reconition
- Set to Yes
Select CU44
- Select Lane Assistance
- Set to ACTIVE
For Heated steering wheel:
Select Gateway 19
- Select Adaptation
- Select Multi-function steering wheel control module-Steering wheel heating button
- Set to Active
Select Air conditioning 08
- Select Adaptation
- Select Steering wheel heating
- Set to short_push
- Select Heated steering wheel and heated steering wheel automatic mode
- Set to Installed
As well i will post a link with the KLR module from aliexpress that make the take over steering message to disapear and the car to drive without your hands on the wheel unlimited time (not recommended)
The KLR module is sitting on the bottom of the steering wheel and is quite easy to swap the boards
https://www.aliexpress.com/item/1005008795628656.html
If admin think this topic is useful you can pinned it
Good luck and enjoy driving your Skoda
Edited by wellaflex
  • wellaflex changed the title to How to: Travel Assist and Heated Steering Wheel Retrofit
  • Replies 71
  • Views 14.9k
  • It's also worth mentioning that the pin assignment changes, which is what the adapter does. Many people don't use an adapter, though. Then you have a problem. SC39 with 10A wire, color red/blue, des
  • On the steering column control unit, it's connector T14e/1, which is terminal 30 for the Z36, with a cross-section of 0.5 mm². Then, T14e/2, which is terminal 31 for the Z36, with a cross-section of 1
  • If we'd like to add the coding for the steering wheel heating: Control unit 08---> Coding ---> Heated_steering_wheel_and_Heated_steering_wheel_automatic_mode Set To Active
Why not the edited data set? I consider the module questionable; it actively interferes with the vehicle's communication... Why are you replacing the steering column switch? The control unit alone would be sufficient... You don't even address the wiring.
I couldn't find any editing available about data set.When you say module you mean the KLR module right? is optional ,they are some people who using it
Actually i didn't know that control unit alone would be enough,i though they a single unit 🫠
I quess about the wiring is not to much to say cause the adapter is mostly plug and play and + and ground are addressed at the end of the video
Edited by wellaflex
SC39 with 10A wire, color red/blue, designation Z36
Edited by Cairus
On the steering column control unit, it's connector T14e/1, which is terminal 30 for the Z36, with a cross-section of 0.5 mm². Then, T14e/2, which is terminal 31 for the Z36, with a cross-section of 1.0 mm².
Don't get me wrong, but something like this simply has to be in the manual. Regarding coding, the instructions always include byte and bit information. Using these information is OBD11-bound.
you right bro
Set To Active
Hi, I was replacing in my Octavia only unit 5q1593 549 from D to F to activate heating. After replacment I got several errors even after coding heated steering wheel . (mainly ACC stop working) Before I installed steering wheel with capacitive sensors and activated TA function, no any errors and malfunctions after first part of retrofit.
5q1593 549F I bought probably from Cupra Leon. It that mean I have upload dataset from Octavia like V03935426TC ?
Autoscan?
3 hours ago, mr25 said:
Hallo, ich habe in meinem Octavia nur die Einheit 5q1593 549 von D auf F ausgetauscht, um die Heizung zu aktivieren. Nach dem Austausch traten mehrere Fehler auf, selbst nachdem ich die Lenkradheizung codiert hatte (hauptsächlich funktionierte die ACC nicht mehr). Bevor ich ein Lenkrad mit kapazitiven Sensoren installierte und die TA-Funktion aktivierte, traten nach dem ersten Teil der Umrüstung keine Fehler oder Fehlfunktionen auf.
5q1593 549F habe ich wahrscheinlich von Cupra Leon gekauft. Bedeutet das, dass ich einen Upload-Datensatz von Octavia wie V03935426TC habe?
After restoring the wiring and module there are no errors. I have 2 modules with letter F, both gernerating different errors, second is probably from Golf. Look like they have differnt configuration inside. Probably only 5Q1953507GF dedicated to O4 kombi will fit without reprogramming.
01 Engine
U021200 - Lost Communication With Steering Column Control Module
09 Central Electrics
U150100 - Local data bus 6 Electrical error Intermittent
B105D07 - Steering column electronics control module mechanical malfunction static
B139029 - Driver side windshield wiper motor Implausible signal Intermittent
13 Adaptive Cruise Control
U112100 - Databus missing message static
U112300 - Databus error value received static
You Code the New one?
You Change the wire by the Connect
Edited by Cairus
No, I still thinking how to do it. I can't connect to 5Q1953507GF or 5Q1953507GD. It is subsystem under 09 module. I was connecting via VCTool but is grey... On stock server I found data set for that module, but I never flashed subsystes. A little bit scare to damage 09. Any advice how to do it ? image.png
Do you have an adapter for the wiring or are you changing the connector directly? The control unit without heating is wired differently than a module with heating.
No I have no adapter, I ordered new 14 pin connector . I was checking 2 times if pins are in right slots. Heating was working with new module
You dont Check the wire with the Plan?
I have access to Elsa, I also checked other threads where is picture of connector. It is exactly the sameimage.png
OK...
With heating
LIN>vi/gn>T14e Pin 5
LIN 2> vi > T14e Pin 12
Looks good.
Pin 6 ist correct? Looks Like Other als 5&4
Edited by Cairus
here is with orginal module:
47 minutes ago, mr25 said:
Ich habe Zugriff auf Elsa und habe auch andere Threads überprüft, in denen ein Bild des Steckers zu sehen ist. Es ist genau das gleicheimage.png
Ist the Unit OEM or AliExpress?
OEM, used module. Production 08 2023. HW and SW he same like orginal.
Which manufacturer do the steering column switches or the winding spring come from?
It was disassembled from 5Q1 953 507 GA. Probably if slipper 5Q159354F comes from 5Q1 953 507 GF will work without problems. GA have different ACC switch so that mean 5Q159354F have different configuration inside. I found that some different software are available, by paying 30 eur I can download GF software. So far I have no idea how to upload that without any damage. I uploaded some datasets into 1 level ECU several times, but this is subsystem. That the reason why I asking if someone have some experience on that.
I wouldn't pay €30 for it. What file or data set do you want?
