How to: Travel Assist and Heated Steering Wheel Retrofit
Coding heated Steering wheel :
Select Gateway 19
- Select Adaptation
- Select Multi-function steering wheel control module-Steering wheel heating button
- Set to Active
Select Air conditioning 08
- Select Adaptation
- Select Steering wheel heating
- Set to short_push
- Select Long coding
- Select Heated steering wheel and heated steering wheel automatic mode
- Set to Installed
  • Replies 67
  • Views 11.5k
  • It's also worth mentioning that the pin assignment changes, which is what the adapter does. Many people don't use an adapter, though. Then you have a problem. SC39 with 10A wire, color red/blue, des
  • On the steering column control unit, it's connector T14e/1, which is terminal 30 for the Z36, with a cross-section of 0.5 mm². Then, T14e/2, which is terminal 31 for the Z36, with a cross-section of 1
  • If we'd like to add the coding for the steering wheel heating: Control unit 08---> Coding ---> Heated_steering_wheel_and_Heated_steering_wheel_automatic_mode Set To Active
Does the aircon coding allow me to turn on the heated steering will from infotainment display too, and eventually turning it on automatically?
Do You also have the coding for the heated seats?
Edited by Benja77
from infotainment display it is only possible to turn on automatically when temperature is low outside ( I don't remember exct value but I think it must be less then 10 deg) , there are 3 levels of heating available. In my case it is working together with heated seats. Important is the starting ignition temperature - it is not working for example if you start engine where temperature is higher then 10 deg and during travelling dropping to 5 deg.
My car is equipped with factory heated seats, so I don't know how to coded heated seats.
Ok thanks! I got the resistences over AE, putting inside the seats and today (or tomorrow) with the mechanic we'll connect pins in BCM; they should work without any coding BUT I just want to to make visible on infotainment screen as OEM. If anybody can help, I'll be more than grateful!
On 23/08/2025 at 14:54, mr25 said:
Hi, I was replacing in my Octavia only unit 5q1593 549 from D to F to activate heating. After replacment I got several errors even after coding heated steering wheel . (mainly ACC stop working) Before I installed steering wheel with capacitive sensors and activated TA function, no any errors and malfunctions after first part of retrofit.
5q1593 549F I bought probably from Cupra Leon. It that mean I have upload dataset from Octavia like V03935426TC ?
Hi I'm facing the same problem, after replacing the factory ring with the 5Q1953569K my ACC/Lane assist stopped working on my 2022 Karoq: it gives me as errror "Travel Assist and Lane Assist temporay not available" --> how did You solve it? It looks like the wheel doesn't communicaty with BCM
Before retrofitting the heated steering wheel with paddles, I replaced once before with normal wheel (not heated) with paddles (factory wheel has not paddles). I also have some column stalk as Yours.
With heated sw, all the other commands/buttons work fine!
Edited by Benja77
  • 3 months later...
On 10/09/2025 at 12:09, mr25 said:
Most probably you need HW: 5Q1953549F Currently in your subsystem 6 - Part No SW: 5Q1 953 507 FN HW: 5Q1 953 549 D. I'm not sure about SW. SW is the same like whole combination switch. Read my case - I was ordered two 5Q1953549F which was not fit due to software inside. Finally I got proper one with both parameters matching my car. My ETKA account was expired so I can't looked in your VIN configuration. Maybe someone else have and make advice.
So I finally finished the heated steering wheel. I used the 5Q1953549F ring with the same SW and HW as the original. My steering wheel is 5E3419093AL VKK. The heating works. However, only on high. When I press the button again to reduce to mid, one line disappears but only for 1ms and then the heating turns off immediately. On high it runs normally without problems but cannot be reduced. Any guesses what can be wrong?
And if in turn on automatic heated steering wheel function and set it on low, it turn on on startup on low and works on low 🤦‍♂️
Which Index have the Gateway?
There is this one
Coding 08 Unit?
Here
If i have combination switch that looks like that already do I need to order new one? Are there soem differences? I have ACC and lane assist.
  • 3 months later...
Hi, i have mk4 2022 limousine without rear wiper. Can someone tell me which part number for the ring+stalk I need?
You can look for 5Q1953507GF and remove the switches and keep only the clock squib
Same problem here after retrofitting my steering wheel to capacitive.
Did you resolve problem?
Solved
Just switched steering wheel heating button to not active.
It's working fine, heating level selection works at it should.
On 11/06/2026 at 13:53, korneliuszm said:
Solved
Been tested this one and i will update the thread
Thank you
Hi, i have the following question:
the car is octavia 2024 with SFD2.
Fitted with lane assist + front assist (but no travel assist package and no ACC).
I saw that OBD eleven have one click app for Active lane guidance and the description is favourable that it would work even for cars equipped with normal Lane assist. The Active lane guidance is feature to help the car stay in between lanes a lot easier than manually doing so. But the question is if it would constantly alarm to make steering wheel input so it knows I'm not asleep since i don't have the capacitive steering wheel. If thats true - would a KLR module resolve this problem and not have to change the steering wheel and make more complex coding?
And since it's SFD2 (not the older SFD) would the coding require any VAG activation? Whats your verdict?
I hope that makes sense.
Thanks.
