29 minutes ago, MartinOctavia1969 said:
Just ignition is ok
Keep the motor turned on !, the last thing you want is your battery to fail
  • Replies 270
  • Views 70.4k
  • For everyone interested, I put the newest versions ALL in ONE link: MIB3_Skoda_SW_1941_1969_1985_1989 I upgraded with this files one by one, no issues. Hope it helped.
  • MartinOctavia1969
    MartinOctavia1969
    I am now looking for making a download link. I think in 30 min of will be there
  • MartinOctavia1969
    MartinOctavia1969
    https://drive.google.com/file/d/1pHhf05ZfCgSUHKWJjW2IAlHXzhsgcllg/view?usp=drive_link Guys this is my first time to share a link with the new 1989 software. Don't be mad if it's not correct. Let me k
O sorry of course if you have a normal engine not EV keep the engine running.
Deactivate star stop, turn of the climate , roll the window ( for fresh air ), keep motor on , you will stay there for a solid 30 minutes , I don't think would be a problem but myself I did not even opened the door , just stay put
Edited by EduardDo
4 hours ago, Dayafterday said:
I am on version 1803 and my vehicle has a swap/fec code for sign reading and maps. If I update, will anything happen to these codes?
Coding still remain and I run the engine during the update
Thanks updated. All 👍
Any possibility for someone to make new link, as i get message from googledrive that it cant be seen or downloaded as too much users on it.
Thanx
BR
Djadjo
Has anyone installed the update? Is there a problem? I can't download via Google Drive, it gives me a limit exceeded warning.
The link on the previous page was fine for me. It said 'no preview available as the file was too large' but it was still downloadable.
Can you check if your CarPlay or Android Auto covers the entire screen? For me, there’s a bezel strip at the top, and its irritating. I want a bigger screen, not a smaller one 😠
Android Auto fits the whole screen don't know with Carplay
14 minutes ago, iloncar said:
CarPlay veya Android Auto'nuzun tüm ekranı kaplayıp kapsamadığını kontrol edebilir misiniz? Benim için üstte bir çerçeve şeridi var ve bu sinir bozucu. Daha büyük bir ekran istiyorum, daha küçük bir ekran değil 😠
Which version has this issue?
20250920_185357.heic
Here's Android Auto. The problem is with versions 1985 and 1989. I thought this update would fix it, but it didn't. Tnx
I don’t know if this is your issue, but bear with me.
When i first got my car, i customised my tiles on the Home Screen. I made the smart link tile one of the ones that was 3x3 big. Smart link would be either Android auto or car play. In this case im using car play.
Anyways, if i wanted it to be full screen, id tap the tile and it would go “full screen” except it didn’t. There would be a border.
The solution for me was to make the smart link tile 1x1. Then when i press it, it would go true full screen with no borders.
Could that be your problem? Since other people are showing screen shots without the border.
Any more news? Everything is stable? Did it fix the issues with Android auto where it does not display the yt album cover or Smth like that?
Everything is stable and works well.
AA no issues at all.
Is there a TPI?
The changelog of the software version?
I mean this
1941 - TPI
It describes the type of problem that Skoda considers eligible for the new software installation.
New software got all last tpi in them
Thanks for providing the link for this - I am based in Australia and note the file (MOI3_EU_SK_R9890L MU1989.7z) says "EU" in it - are there any risks with loading versions not specifically designed for your region?
