Door speaker part code
Hi.
One of my front door bass speakers has no sound and the other is crackling badly.
Does anyone know the correct part number as there seems to be at least three or four variants
3V0 035 411 (A, J, K or L?)
Or as I’m in there changing speakers is it worth going aftermarket?
Car is 65 plate SE L Executive 190 TDI DSG with standard (not canton) speakers.
Knew I’d seen something’s about speakers recently. I am pretty sure it has been said that there was no difference in the speakers between standard and Canton - just the DSP and amp/sub.
Part numbers
Great thanks. So 3V0 035 411 K seems to be the ones to go for.
I googled to be sure:
Part number
3V0035411J
is a genuine Skoda/Volkswagen Group bass loudspeaker(woofer) used across several current vehicle models.
Product Specifications
  • Part Type: Bass Loudspeaker / Woofer.
  • Driver Type: Midrange/Bass.
  • Impedance: 4 Ω.
  • Weight: Approximately 0.66 kg to 1.08 kg depending on packaging.
  • Placement: Suitable for both front and rear door installations.
Vehicle Compatibility
This speaker is specifically designed for vehicles equipped with upgraded audio packages, such as the Canton Sound System. It is compatible with:
  • Skoda Superb MK3 (3V): Models from 2015 through 2024.
  • Skoda Karoq (ND/NU7): Models from 2018 onwards.
  • Skoda Kamiq (NW): Models from 2019 onwards.
  • Skoda Scala (NW): Models from 2019 onwards.
  • Seat Ateca (5FP): Models from 2016 onwards.
Key Differences from 3V0035411K
While both parts are woofers for similar vehicle platforms:
  • 3V0035411J is often listed as the standard bass speaker for a wider range of models including the Kamiq and Scala.
  • 3V0035411K (mentioned previously) is more specifically associated with the high-performance Canton setups in the Superb and Karoq.
  • The "J" version may be interchangeable with the "A" version (3V0035411A) in some catalogs.
I think that K is Canton and J is standard. J is updated version of A. As an aside L looks to be rear door so that’s irrelevant.
I’m putting my money on J if yours is non-Canton.
3V0035411D-----> D >> - 07.01.2019
3V0035411K-----> D - 07.01.2019>>
both Canton Soundsystem Front door
3V0035411J:
PR Code: 9VD Speaker (active)
PR Code: 8RL 6 speakers (passive)
PR Code: 8RM 8 speakers (passive)
PR Code: 8RE 4 speakers (passive)
Edited by Cairus
